    Yep sounds like the cylinder is at fault
    Lives in East Lothian, United Kingdom. Last Activity: 4 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    The fact the problem reverses, makes me think it's more likely to be the solenoid failing.
    When the air is exhausting, remove the hose from the non-pressurised side of the cylinder (i.e if it's pressured into the spindle, remove the hose at the spindle end). If it's the cylinder that's leaking, then the air will escaping from the cylinder. If it's coming out the hose, or there's no change, then it's likely to be either the solenoid, or something lose/broken near the solenoid (I have seen the pressfit couplings simply fall apart and start leaking with age).
    I'm not sure what machine you've got, but if it's a separate control box, the solenoids are all mounted in a box on the rear of the machine. I think if it's a machine with built in control box, then they're in the main control box.
    If you do need a cylinder, I should still have a new one kicking around.
    Hi I had a similar fault on my triac this week where the carousel would only travel 1 way when it should of retracted the solenoid just exhausted air out. I stripped the solenoid and found it was traveling further one way than the other, I figured it to be the internal clear seal was damaged, these have been discontinued so I just fitted a similar sized O ring now all is fine. I figured that the 2 clear seals are there to limit the solenoid piston travel. The cost of a replacement solenoid is getting on for £100. Hope this helps
    Ade
    I thought it probably would be the solenoid as the cylinder is fairly new. If I take off the pipe at the spindle end, no air escapes from the cylinder and carousel is pushed firmly up to spindle.
    I have the machine with the built in control cabinet, solenoids are top right.
    Is it this part that would need replacing?
    https://uk.rs-online.com/web/p/produ...E&gclsrc=aw.ds
    Or this bit...
Name:	Solenoid Valves close up.jpg
    Good question. I never realised these used pilot operated valves, so it could be either part causing the problem.
    I'd try swapping the pilot valves (...378 part) around first, as it could be a seal between the pilot valve and 4/2 valve body causing the problem. If the seals are ok, then you can see if the fault moves or stays.
  1. FOR SALE: Denford Triac PC inc Denford table plus chucks, and Denford CD software etc
    By Piero franchi in forum Items For Sale
    Last Post: 14-02-2017, 04:47 PM
  2. FOR SALE: Denford Triac + Denford Orac + other stuff
    By Clive S in forum Items For Sale
    Last Post: 06-02-2017, 11:47 PM
  3. FOR SALE: Denford Triac PC
    By Todd in forum Items For Sale
    Last Post: 10-01-2017, 01:42 PM
  4. FOR SALE: Denford Triac CNC PC
    By ricey3 in forum Items For Sale
    Last Post: 10-01-2017, 01:39 PM
  5. Denford Triac Spindle Fault
    By Sam_Smith in forum Denford Mills
    Last Post: 04-05-2011, 11:07 PM
