    Hi there im trying to find out what the Chester Champion 20v Mill is . My plan is to convert it to cnc with a kit but i need to know is it the same as the Grizzly G0704 ? or the PM-25MV ? or something else. You can get kits for most of them but they arnt all the same . So i need to know what it is befor i order the wrong thing ? Any one have any Idea ?
    ThanksMick
    Ask Chester machine tools...?
    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    I very much doubt Chester would tell you.
    Most of these machines, especially from the bigger suppliers, all have slight variations. I know a couple years ago I looked at something G0704 like, and out of all the different machines around that size I looked at (around 8 to 10 IIRC), they all had slightly different specs. Some were obvious things like different spindles, and others were more subtle like axis having slightly different amounts of travel.
    Iv msged Chester 3 or 4 times without reply. It's the bolt holes for the bearing mounts that's most important. If these are the same as the grizzly I know I can bolt the kit on. I can work around the rest
    Don't bother with the Chester imo.
    1. The Y travel is way short at 155mm.
    2. The taper MT2, no thanks!
    A better variant is the AMAT25LV from Amadeal. R8 taper avail which is best imo. Has more powerful motor, belt driven, higher rpm. If you're going to spend around £1200 then for me that's the one to get (and I am).
    There's no guarantees the G0704 kit will fit any of the variant mills I'm afraid but the one I've mentioned has the best chance.
    Haha this is old news IV already CNC ed it
    Quote Originally Posted by amxen View Post
    Ha ha :D
    Realised after I posted it. Not much activity on this site most of the time.
    Did the kit fit the Champion then mate? Or you go with something else.
    Yer got the kit from Arizona 99 fit really well and easy
    They look pretty smart his kits.
    My AMAT25LV should be here on Friday.
    Just about to start re-building my Seig X2 so it can make a kit for the 25.
    It's a bit worse for wear atm and I want it bang on.
    Then it's a case of measure up, order some double nut screws from China (re-shim them), make some mounts & get some Oldham coupling inserts from RS and make some hubs.
    What could poss go wrong!!! lol.
    If it goes belly up I'll have a word with Arizona :D
    Hey,
    Sory for startiung up this old thread again, but was it the PM-25 kit from Arazona 99 you went with for the Champion 20v??
    Thanks,
    Kolin
  1. Chester 626 turret mill
    By Robin Hewitt in forum Machine Discussion
    Last Post: 29-08-2017, 04:40 PM
  2. Replacement gears for Chester Champion 20V mill
    By CharlieRam in forum Milling Machines, Builds & Conversions
    Last Post: 14-04-2016, 10:19 PM
  3. RFQ: Modifications to a Chester 16V Mill
    By Tom_Nelson in forum Projects, Jobs & Requests
    Last Post: 09-09-2015, 07:47 PM
  4. FOR SALE: (G0704 SPG 2217 Champion 20V Mill Warco WM 16) DC motor
    By fragger6662000 in forum Items For Sale
    Last Post: 09-10-2011, 05:59 PM
  5. Chester tools champion 16v milling machine conversion
    By NICKMODELMAKER in forum General Discussion
    Last Post: 26-02-2010, 09:29 AM
