    Can the DIR+ be daisy chained to each drive's DIR+?
    Of course.
    Rye's Avatar
    Lives in Sheffield, United Kingdom. Last Activity: 16-02-2019 Has been a member for 9-10 years. Has a total post count of 50. Received thanks 4 times, giving thanks to others 0 times.
    Thanks Clive. I think I've done it right. Well, I hope I have :)
    Bought a Chinese 6040...if only I'd known better :(
    Moy Bien
    Rye's Avatar
    Too cold to be in the shed cutting aluminium for the rest of the box, so I've made a start wiring the steppers on the DDCS:
    Couldn't be bothered with soldering, so got me two 37pin D-Sub breakout boards: one for the main box, one for the DDCS box(when I get around to making it). Takes up more room, but easier than soldering 37 pins :)
    Rye's Avatar
    Found a little time to continue with this. The main box is pretty much done. Admittedly, it's all a bit tatty and meccano..ish, but it'll do for the shed wall. All powers up fine, just need to tidy the wiring before I wire the D-Sub for the limit switches.
    Still need to make the box for the DDCS. The DDCS powers up, but have to wire the MPG/switches. estop, pump-switch and possibly one or two other things. Going to try wiring up first to see if it all works.
    Dang! Where do I start :(
    Might need some help wiring the 5 position rotary switches for X,Y,Z and 1x, 10x, 100x on the MPG control.
    Rye's Avatar
    Had a slight change of plans on the design for some of this, but the wiring and everything is coming together quite nicely.
  1. 5 axis BoB spindle control help needed
    By Noddy in forum General Discussion
    Last Post: 07-03-2018, 09:58 PM
  2. Control box
    By Kev2960 in forum Gantry/Router Machines & Building
    Last Post: 03-02-2017, 11:14 PM
  3. Exractor control
    By gorbo in forum Workshop & Equipment
    Last Post: 24-12-2015, 03:06 PM
  4. Advice Needed - Control Panel
    By GTJim in forum General Electronics
    Last Post: 18-04-2013, 08:23 AM
  5. servo control vs stepper control
    By Peter. in forum Motor Drivers & Controllers
    Last Post: 17-09-2012, 08:36 AM
