Thread: Newbie (ageing rapidly!)
MM: I don't have the NVUM, but do have the NVEM (the ethernet variant), and can say that they are largely okay, but come with issues, the first one being that they have a fixed pulse width of 2.25us output to the stepper drivers, from memory (and that ain't great) negatively switched but capable of sourcing or sinking current. The default installation in the manual suggested switching the positive input to the stepper driver and grounding the negative input - with my cheap stepper drivers that lead to the LED in the optocoupler being "On" significantly longer than "Off", coupled with the low performance optocouplers (4n25) and saturation on the phototransistor meant that the stepper drivers were missing steps (scoping input vs output showed a grim transfer function). So, word of warning on the NVUMs (assuming the motion controller is largely the same) - check that you're not in a position described above, changing the arrangement above can help (as can better stepper drivers or replacing optocouplers.... but you're a way from that yet by the sounds of things).
I've never tried USB on a CNC machine (only PPBoB and Ethernet). I did, however, once have a USB interface to a RepRap 3d printer. That was temperamental (occasional missed instructions which lead to offsets in the print space) and a shared view on the inter web pointed at the reliability of USB. Fortune smiled upon me and I managed to shear off the micro USB socket from the board by tripping over the cable - the easiest fix for me was tacking a bluetooth serial interface directly onto the Melzi board. Strangely, BT was infinitely more reliable than USB in that environment. I think USB and steppers and potentially disimilar grounds don't co-exist well.
The NVUM ??? plugin buttons - I have those with the NVEM. Not figured out which button does what but again, from memory, there's only a couple of very basic options to play with on the config screen, so long as those "stick" then the two buttons are likely OK and CANCEL - press one and check the config sticks. The ddream driver - sounds about right - and I think indicates this is likely a rip-off controller, but works to a fashion for me on a NVEM.
Open up the NVUM - you should find the inputs are Optocoupled already so external conditioning is not really needed. Just be aware that the ABS injection moulded case - the receptacle for the screws doesn't butt against the mating face on the other half of the case - so it's easy to overtighten and rip the plastic apart. Tighten to 0 white-knuckles loading.
What exactly doesn't work for you with the NVUM? I guess you've tried jogging with no joy?, I know with the NVEM driver on first start-up I can find (though never really bottomed it) that I can't jog until I home the machine. Maybe a driver issue, but I usually have a 2 minute tussle persuading the machine to start moving - either a G1 X1 feed through the MDI or a home resolves and I then get distracted and never investigate further.Last edited by Doddy; 24-02-2018 at 10:15 AM.
23-02-2018 #2
JazzCNC,
I completely agree, after consulting n people I had at least n+1 options! I did consult a lot of people and did my research. I admit being caught out by the USB powered BOB was down to me but every other controller has been based on recommendations / reviews and a detailed set of questions sent to the supplier. Sadly the sales departments of most companies simply say what ever the customer wants to hear and claim you must have misunderstood when challenged after the sale. That's why I record all phone conversations. It won't cost me a penny for products that don't work.
23-02-2018 #3
Please don't get me wrong here I'm not having a go at you just pointing out to others these things need research and acceptance that it can't be done on shoestring budget.
Now you say you had advice. Then I suggest you change who you ask because can tell you without a shadow of a doubt no one here would recommend any of those choices you made.
Those that know would never advise USB and nearly always point you to Ethernet-based controllers unless cost was the issue, even then would issue caution regards USB because it's flaky. Or would point to other very capable alternative systems like Linux CNC and Mesa cards etc.
While Mach3 is aging and starting to lack behind others in some areas of software it isn't the problem you have been experiencing. Mach3 is very capable software with 10,000's of users working on whole variety of different types of machines and hardware.
Your problem comes from the fact those cheap or fake controllers have no support for the plug-ins and Mach3 over the years has had many updates which break these plug-ins which are no longer updated.
Any Device is only good as the support from the supplier regards the Plug-in. Without this, it's just becoming an expensive paperweight.
Mach3 does work on 64Bit systems and on Win10 perfectly fine. It's the parallel port driver that doesn't so is restricted to 32bit but PP is dinosaur and only fitting it should go the same way.!
Now in order to help and guide you, we need to know more about the machine and what your needs are.Last edited by JAZZCNC; 23-02-2018 at 07:14 PM.
23-02-2018 #4
The ?? would tell me either the translation is missing, or it's trying to use characters that don't exist on your computer. It shouldn't stop things from working.
There are 3 different plugins listed here - http://www.nvcnc.net/nvum.html
Probably worth trying them all, to see if you any connect to the controller.
And just to cover the basics, you have connected a suitable 12-32VDC supply to the controller?Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
