Thread: 1220 × 2440 build
Let's see if it works on this app. I just took some photos of the screen. I keep changing my mind about the lay out as I'm learning a few things from drawing. After all, my first drawings where based on scratch building.
I started out with the linear bearings actually on top of the aluminium profile (not shown in pics) but I was worried about the lateral forces when the gantry was in the middle of the x axis cutting along the y, what do you think? It's 90 x 45mm heavy profile. Looks like it would be pretty strong in the corners.
It seems using the aluminium profile for some parts makes getting everything square easier. That's why I was going with a separate structure for the base, but I seem to have gone a bit ott with the aluminium now.
After seeing the other picture though I've attached, this was another idea I had, although the one pictured looks a little weedy (I think?), I think maybe it could be beefed up a bit (lot). Pretty much by combing both designs
I've settled for less y axis travel, I want to be able to do 3d stuff on this machine too, do we think it's possible? It's down to the software I guess? Obviously they won't be coming from my drawings haha I'll be using a CAM program to import someone else's.
Sent from my SM-G935F using Tapatalk
03-03-2018 #2
If you was building a plasma machine I'd say that's perfect. But if you want a serious router then it needs lot more work.
The Bottom Pic looks very much like Merchant Dice machine and just ask anyone about how well MD machine performs..
Your gantry design is week and far too weedy for decent router this size.
03-03-2018 #3
the gantry looks a bit too low to me, id say try to get this a rock solid as possible, I thought machine was solid but turns out the ready made z axis assembly is not solid enough, getting vibration when cutting 18mm mdf in one pass, It the only bit that hasn't got hiwin rails, will changing it soon and ill be changing my spindle for an ATC spindle
03-03-2018 #4
Ah sorry to hear that, but thanks for letting me know. I was considering just buying theirs. I tried to keep the gantry as low to the rail as possible. Droping the bed lower instead of raising the gantry seems like it'd be stronger.
I need to go see my engineer now I have a little more idea about what I want. Doesn't seem too difficult to make the z axis from scratch.
03-03-2018 #5
the guy jazzcnc sent a link to an American site that looked good, they have a preassembled part that I really like the look of
https://www.aliexpress.com/item/CNC-...6ab831b0ZkP59s
03-03-2018 #6
05-03-2018 #7http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
The Following User Says Thank You to Desertboy For This Useful Post:
05-03-2018 #8
03-03-2018 #9
if you look at my c beam picture, I joined 3 bits of aluminium together, this is ridiculously rigid but very heavy! if I could do this again id use light weight aluminium profile instead! I have no doubt it would be still as rigid, keeping the weight down would be a good idea because the gantry is cumbersome and requires a lot of power to heave it about, the x axis struggles while the y axis flies
I'm not so sure keeping it so low wouldn't ending up causing you problems down the line. also when I'm making a new base for my machine I plan to make the underside suitable for sheet storage, my workshop is small and the machine swamps the place so sheets lying around are a real painLast edited by malcolm01; 03-03-2018 at 11:01 PM.
03-03-2018 #10
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
BUILD LOG: New Build Log ... 2440 X 1220 X 300
By Wobblybootie in forum DIY Router Build LogsReplies: 30Last Post: 17-10-2014, 11:20 AM -
WANTED: 3 bits of 250 by 1220 by 40mm t-slot, 1220 16X5 threaded rod and isel ballscrew, plus
By nobby in forum Items WantedReplies: 1Last Post: 01-03-2014, 01:31 AM -
BUILD LOG: Steel Router 610 x 1220 x 200
By Stickio in forum DIY Router Build LogsReplies: 12Last Post: 18-08-2011, 07:27 PM
