    if you look at my c beam picture, I joined 3 bits of aluminium together, this is ridiculously rigid but very heavy! if I could do this again id use light weight aluminium profile instead! I have no doubt it would be still as rigid, keeping the weight down would be a good idea because the gantry is cumbersome and requires a lot of power to heave it about, the x axis struggles while the y axis flies
    I'm not so sure keeping it so low wouldn't ending up causing you problems down the line. also when I'm making a new base for my machine I plan to make the underside suitable for sheet storage, my workshop is small and the machine swamps the place so sheets lying around are a real pain
    Quote Originally Posted by malcolm01 View Post
    if you look at my c beam picture, I joined 3 bits of aluminium together, this is ridiculously rigid but very heavy! if I could do this again id use light weight aluminium profile instead! I have no doubt it would be still as rigid, I'm not so sure keeping it so low wouldn't ending up causing you problems down the line. also when I'm making a new base for my machine I plan to make the underside suitable for sheet storage, my workshop is small and the machine swamps the place so sheets lying around are a real pain
    Yeah I spent a little while trying to find one like it until I looked at the picture more closely! Nice idea about storage ... is the base of yours made from wood?
    Sent from my SM-G935F using Tapatalk
    Quote Originally Posted by HullMark View Post
    I think I'll maybe go with your c beam then, it's an option for sure
    yes I built a torsion box from mdf, stupid idea, my idea was to pivot the machine against the wall when not in use, terrible idea so I plan a new table, mix of steel and aluminium, I was thinking if you used Turbocad id have sent yiu my drawings of my machine, theyre a bit ruff but you might have seen something usefull
  5. The Following User Says Thank You to malcolm01 For This Useful Post:
There are currently 50 users browsing this thread. (0 members and 50 guests)
  2. BUILD LOG: New Build Log ... 2440 X 1220 X 300
    By Wobblybootie in forum DIY Router Build Logs
    Last Post: 17-10-2014, 11:20 AM
  3. Replies: 1
    Last Post: 01-03-2014, 01:31 AM
  4. BUILD LOG: Steel Router 610 x 1220 x 200
    By Stickio in forum DIY Router Build Logs
    Last Post: 18-08-2011, 07:27 PM
