    Never said was just bolted to brackets. In fact, it's not that simple.!
    There would be adjustment bolts between profile and steel to get the two rails parallel because couldn't rely on the frame being perfectly square.
    These are the hidden things which cannot be seen but make a huge difference to how well the machine performs. Again can't stress enough always think adjustability when designing.
    Thanks for getting back to me. Ahh I see! So how would you go about fixing those adjustment bolts to the steel frame? Showing my inexperience here. I was wondering about how with my design I could get the profiles lined up along the x axis (this is why I want ott with the aluminium in the earlier design), adjusting the height along the length wouldn't be a problem with those cleats, could just use shims ... I had an idea for the x axis, but it isn't empirical or anything, just basically a bit of measuring and trial and error.
    I appreciate what you're saying about being able to make adjustments, i can imagine all of the that could go wrong if things aren't aligned properly, and making things adjustable will allow me to get everything dialled in.
    Sent from my SM-G935F using Tapatalk
  2. BUILD LOG: New Build Log ... 2440 X 1220 X 300
    By Wobblybootie in forum DIY Router Build Logs
    Last Post: 17-10-2014, 11:20 AM
  3. Replies: 1
    Last Post: 01-03-2014, 01:31 AM
  4. BUILD LOG: Steel Router 610 x 1220 x 200
    By Stickio in forum DIY Router Build Logs
    Last Post: 18-08-2011, 07:27 PM
