Thread: 1220 × 2440 build
03-03-2018 #11
Let's see if it works on this app. I just took some photos of the screen. I keep changing my mind about the lay out as I'm learning a few things from drawing. After all, my first drawings where based on scratch building.
I started out with the linear bearings actually on top of the aluminium profile (not shown in pics) but I was worried about the lateral forces when the gantry was in the middle of the x axis cutting along the y, what do you think? It's 90 x 45mm heavy profile. Looks like it would be pretty strong in the corners.
It seems using the aluminium profile for some parts makes getting everything square easier. That's why I was going with a separate structure for the base, but I seem to have gone a bit ott with the aluminium now.
After seeing the other picture though I've attached, this was another idea I had, although the one pictured looks a little weedy (I think?), I think maybe it could be beefed up a bit (lot). Pretty much by combing both designs
I've settled for less y axis travel, I want to be able to do 3d stuff on this machine too, do we think it's possible? It's down to the software I guess? Obviously they won't be coming from my drawings haha I'll be using a CAM program to import someone else's.
Sent from my SM-G935F using Tapatalk
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
BUILD LOG: New Build Log ... 2440 X 1220 X 300
By Wobblybootie in forum DIY Router Build LogsReplies: 30Last Post: 17-10-2014, 11:20 AM -
WANTED: 3 bits of 250 by 1220 by 40mm t-slot, 1220 16X5 threaded rod and isel ballscrew, plus
By nobby in forum Items WantedReplies: 1Last Post: 01-03-2014, 01:31 AM -
BUILD LOG: Steel Router 610 x 1220 x 200
By Stickio in forum DIY Router Build LogsReplies: 12Last Post: 18-08-2011, 07:27 PM
