Thread: 1220 × 2440 build
if you look at my c beam picture, I joined 3 bits of aluminium together, this is ridiculously rigid but very heavy! if I could do this again id use light weight aluminium profile instead! I have no doubt it would be still as rigid, keeping the weight down would be a good idea because the gantry is cumbersome and requires a lot of power to heave it about, the x axis struggles while the y axis flies
I'm not so sure keeping it so low wouldn't ending up causing you problems down the line. also when I'm making a new base for my machine I plan to make the underside suitable for sheet storage, my workshop is small and the machine swamps the place so sheets lying around are a real painLast edited by malcolm01; 03-03-2018 at 11:01 PM.
03-03-2018 #2
03-03-2018 #3
03-03-2018 #4
yes I built a torsion box from mdf, stupid idea, my idea was to pivot the machine against the wall when not in use, terrible idea so I plan a new table, mix of steel and aluminium, I was thinking if you used Turbocad id have sent yiu my drawings of my machine, theyre a bit ruff but you might have seen something usefull
The Following User Says Thank You to malcolm01 For This Useful Post:
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
BUILD LOG: New Build Log ... 2440 X 1220 X 300
By Wobblybootie in forum DIY Router Build LogsReplies: 30Last Post: 17-10-2014, 11:20 AM -
WANTED: 3 bits of 250 by 1220 by 40mm t-slot, 1220 16X5 threaded rod and isel ballscrew, plus
By nobby in forum Items WantedReplies: 1Last Post: 01-03-2014, 01:31 AM -
BUILD LOG: Steel Router 610 x 1220 x 200
By Stickio in forum DIY Router Build LogsReplies: 12Last Post: 18-08-2011, 07:27 PM
