    I had the following setup in my control box:
    my previous BoB JP-3163B was connected by the PSU at -V connector to the main on/off switch and then onto the Grounded slot on the BoB.
    my new BoB does not have a grounded slot for this wire to go into and is powered via USB http://www.ebay.co.uk/itm/Upgrade-Us...53.m2749.l2648
    what do I do with the on off switch do I have it as part of the chain for the stepper motors now? or does it go into either the -5 or +5 slot on the board? I don't know and I feel a bit concerned that when the mains is switched on the psu and stepper motors would be live?
    my stepper motors are https://www.ebay.co.uk/itm/CNC-Singl...53.m2749.l2649
    I have a 24v PSU which is the original.
    my Breakout board which had the stepper motors chips altogether was at fault so had to replace with the above.
    If someone can kindly explain the wiring setup it will be very much appreciated.
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    If your BoB is POWERED by USB (caps, to emphasise that the BoB is only powered by USB, but signalling is still by parallel)...
    Keep it simple. Use the power switch to power the stepper drivers. If they are de-powered then the motors ain't moving. Even if the BoB is powered via USB, if the switch is off, the steppers won't move.
    You're more likely to introduce problems if you try to switch the BoB power supply.
  3. The Following User Says Thank You to Doddy For This Useful Post:
    the Chinese BOB can be powered 2 ways
    either via the USB connector or
    connecting a 5V power supply to the 5V input screw terminals
    the switch selects which powers the board
Name:	chinese breakout board.jpg
    note :-
    the input circuit for pins 10 to13 +15
    has an design error the 74HC14 is missing the 5V supply to pin 14 !!
    adding a wire link to pin 14 on the adjacent IC solves the problem
    John
    PS
    can you give more details of the on/off switch
    do you mean E-stop switch ???
  1. 12v --> 10v Nowforever D100S2R2B inverter & MKS-V-V02 CDXHCTECH board
    By CarecaIII in forum Motor Drivers & Controllers
    Last Post: 09-01-2018, 12:47 AM
  2. VFD to USB WIRING ????
    By Stucncusb in forum Spindles & Drive Motors
    Last Post: 23-08-2013, 07:06 PM
  3. cnc wiring
    By crossleymarko in forum Gantry/Router Machines & Building
    Last Post: 09-04-2012, 09:35 PM
  4. wiring help
    By deannos in forum Motor Drivers & Controllers
    Last Post: 08-06-2011, 02:20 PM
  5. help me for wiring
    Last Post: 28-11-2010, 01:20 PM
