    Just as the title really, I have been loaned a transwave static converter to try on my Boxford 250.
    I was going to try it as I ve heard that multi motor machines wont work on a static converter.
    Question is will I damage the converter (as its not mine) or worse still damage the lathe if it dosnt work properly?
    Its a 1990's Fanuc Ot controller if that helps.
    Thanks in advance
    what parts of the Boxford 250 need to be run from a 3 phase supply ?
    I would think the Fanuc controller could be run of the single phase supply
    how intelligent is the transwave static converter ?
    if you have to select the capacitors to generate the 3rd phase
    then the phase to phase voltages will change wildly as you switch the various motors on and off
    and risk damaging any motor speed control
    example of simple converter that would not work for your machine
Name:	simple 1 to 3 phase converter example.jpg
    John
    Last edited by john swift; 28-02-2018 at 01:05 PM. Reason: add simple converter example
    Its the spindle inverter, ac servo drives and the coolant pump. the main Fanuc controller is 110v
    The converter is a Transwave 5.5Kw cant see a model no. but the serial is XHD18487STC
    As it not mine I dont want to open it up to see if its like the example. cheers
    My understanding of static inverters is that they work fine for loads within their rated range, but are not happy with loads that are too small. A 5.5KW inverter is pretty big and will probably have a correspondingly bigger minimum load. Generally I believe that they are happy with running multiple motors BUT the total load must be within the rated range. So, a big lathe might use one for the main drive motor and would be happy with lube/coolant pumps running at the same time but would probably not start aforesaid lube/coolant pumps without the main motor running.
    I would have a look at the Transwave site to see if they give specs there for the permitted range of loads, including minimum load.
Name:	20180215_190348 (002).jpg
    Looks like 0.75kw min on the plate and the spindle motor is 1.5kw. not sure if the ac servos will pull enough though to move the axis without the spindle running.
    Lives in East Lothian, United Kingdom. Last Activity: 7 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Static converters are no good for anything other than direct motor loads. They rely on the motor spinning, and the corresponding load/backemf and a bank of capacitors to create the generated leg. Without the spinning motor, the generated leg voltage will be all over the place. Even with a motor attached, the generated leg voltage will vary during changing loads. More advanced static converters let you switch capacitors in/out to try and compensate, and some even do it automatically for you.
    However, what you could do, is attach a reasonably sized motor to the static converter, and you have a rotary converter.
  1. Step/direction to analogue converter
    By Agathon in forum Control Hardware & Systems
    Last Post: 10-08-2017, 08:58 AM
  2. Massive Static sparks in dust shoe
    By mturneruk in forum General Discussion
    Last Post: 20-01-2016, 12:01 AM
  3. Struggling with USB to RS485 USB-485 Converter
    By kingcreaky in forum Computer Hardware
    Last Post: 25-08-2013, 08:04 PM
  4. Replies: 0
  5. FOR SALE: AXYZ USB to RS-485 optically isolated converter for sale £260 ono
    By RickyThunders in forum Items For Sale
    Last Post: 18-07-2011, 11:30 PM
