	23-01-2020 #21
Hello I´m Stoandl from Austria and hope to get support in this thread .
I use mach3 , CSMIO IP-M and the wireless MPG WHB04B.
The problem is -when using the MPG - z-axis does not move anymore with the keyboard button (pg-up,pg-down) x-axis and y-axis work as usual with the arrow buttons.
Does anyone have an idea to solve the issue ?
thanks Stoandl
	23-01-2020 #22
I use the same pendant with mach3 on a mill and have no issues with movement of any axis using the mpg or the keyboard keys
The mill is controlled through a standard parallel port
	24-01-2020 #23
I have a very similar setup and also have some problems with it. I posted something about two weeks ago describing my problems. I'm not sure that the arrow keys work on my Mach3 screen, but I have never worried about it as I always use the MPG for jogging. I'm not surprised, though - there do seem to be some issues with this particular combination of hardware.
	24-01-2020 #24
	24-01-2020 #25
Yes, there is a known incompatibility between the CSMIO-IP/M plug-in and the latest versions of Mach3. I am running a slightly older version of Mach3 to avoid the problems which stopped my tool-height setting macros from running correctly. Over the last year or two I have been starting to find one or two other issues which I am still trying to understand but which seemed to arrive when I started using the MPG. Your "jogging" problem is one that I noticed recently but because I do not use the feature I was not sure if it was a real problem or that I had forgotten how the facility worked! I have to say that I do like my MPG and it is always in use for any job I am doing.
Pendant controller
By alboy in forum General DiscussionReplies: 2Last Post: 26-10-2016, 10:01 PM -
Initial workpeice tooling set-up instructions using a pendant controller type machine
By Nthkentman in forum Machine DiscussionReplies: 25Last Post: 30-08-2014, 08:33 PM -
What should a pendant look like?
By Neale in forum General ElectronicsReplies: 3Last Post: 30-08-2014, 12:02 AM -
JOG IT Pendant
By Leadhead in forum Marketplace DiscussionReplies: 19Last Post: 12-11-2013, 06:45 PM -
CNC Pendant with 100 MPG
By Lee Roberts in forum General ElectronicsReplies: 5Last Post: 04-03-2009, 07:09 AM
