03-09-2009 #2
The tool is way too big, you want a smaller one. If the clamp doesn't have a vertical adjust you need lots of convenient sized shim to put under it for adjusting the centre height.
To cut a vee groove without CNC you might want to use the top slide set around at the correct angle so that the tool cuts on it's leading edge.
The world has gone carbide crazy, I think you want the slicing action you get from freshly ground HSS with relief angles front and top. It takes a much better edge. After grinding, round the sharp point off the end with a couple of strokes with a diamond hone, not so much as you can see without a microscope, and it will cut smooth rather than tearing the surface
Miniature Lathe for Pen Turning - Brushed or Brushless Motor?
By Nealieboyee in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 29-10-2012, 11:34 PM -
Mini Lathe Part
By fragger6662000 in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 15-11-2011, 07:13 PM -
FOR SALE: Sieg C3 Mini Lathe
By Jonathan in forum Items For SaleReplies: 1Last Post: 07-05-2011, 06:19 PM -
A Mini Lathe
By irving2008 in forum Milling Machines, Builds & ConversionsReplies: 19Last Post: 03-05-2010, 04:11 PM -
WANTED: SIEG C3 Mini Lathe
By derekm in forum Items WantedReplies: 5Last Post: 07-04-2010, 08:35 PM
