Page 2 of 2 FirstFirst 12
    I think it's what would be classed as prior experience. In business time = money. So if the person wanting the quote can't be bothered supplying all the details required upfront, that costs time. Now as somebody who occasionally quotes for jobs, I want to see the information up front, so I can make a decision on if I'm able to do it, not waste time sending PMs to get that information.
    Let's get this straight: all you need to know in order to see if you're interested in the job or not is in my first post. Just ask yourself few simple questions:
    Am I happy milling 10mm delrin with a 1.5mm bit?
    Am I happy milling 14 x 50-150mm shapes out of delrin?
    If the answer is yes, you get the dxf file and that's that. You don't need to know gear profile, you don't need to know bore. What's with all this hand-holding?
    I made custom gears before. I milled them top down with a 1mm endmill (13 mm flute).
    I've seen Chaz's gear's and they were spot on, too much work for me.
    Make a mold and nylon cast them is another possibility.
    Lives in East Lothian, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 375 times, giving thanks to others 9 times.
    Quote Originally Posted by Miller View Post
    Yes.
    Yes.
    I can see a dummy lying on the ground, but no hand-holding.
    You're being rather presumptuous. Did you express an interest in the job and you didn't get what you need?
    Er, No, Forum etiquette is to quote only in response to RFQ, you hadn't made one at that point.
  5. #15
    Your answer as to why professional shops will not touch this is in there, no one wants to make scrap and if you can't tell them and it's not specified on the drawing then they probably assumed you were a somewhat clueless Model Engineer and filed it under B 1 N
    P.S. I just realised that you don't know if they're MOD, DP, something else or a hash-up
  6. #16
    Post Duplication
  1. china 40W Co2 laser stopped cutting
    By Ross77 in forum Laser Machines & Building
    Last Post: 06-05-2017, 08:37 PM
  2. Newbie - Help With Laser Cutting Speed And Power - 60W Laser
    By nickpscott in forum Laser Machines & Building
    Last Post: 11-11-2015, 10:07 PM
  3. Laser cutting Machines
    By Want2build1 in forum Laser Machines & Building
    Last Post: 13-05-2014, 01:58 PM
  4. laser cutting ally plate
    By i2i in forum Tool & Tooling Technology
    Last Post: 21-02-2013, 08:47 AM
  5. Laser cutting 10mm acrylic?
    By camhguh in forum Laser Machines & Building
    Last Post: 04-09-2012, 12:51 AM
