    Wonder if you had a CNC with 4th axis (i.e stepper driving a horizontal chuck bolted to the bed) and created a form tool to go in the CNC collet you could do it?
    Or a manual dividing head for that matter.
    So work piece is a round blank, 10mm thick, but held vertically say on a mandrel. CNC machine a valley between 2 teeth at the 12 o'clock position above the work using the form tool, then index the work around one tooth worth and continue until all teeth are cut? Then you are only reaching in by the depth of the tooth and not the width.
    Or come in at the 3 o'clock position with a sideways form tool?
    More ideas here [08:17]
    https://www.youtube.com/watch?v=3wd8wE_VxPo
    You could stack up a few parts and cut them all at once, maybe using a tailstock for support?
    Chaz's Avatar
    I made custom gears before. I milled them top down with a 1mm endmill (13 mm flute).
  3. The Following User Says Thank You to Chaz For This Useful Post:
    I've seen Chaz's gear's and they were spot on, too much work for me.
    Make a mold and nylon cast them is another possibility.
  1. china 40W Co2 laser stopped cutting
    By Ross77 in forum Laser Machines & Building
    Last Post: 06-05-2017, 08:37 PM
  2. Newbie - Help With Laser Cutting Speed And Power - 60W Laser
    By nickpscott in forum Laser Machines & Building
    Last Post: 11-11-2015, 10:07 PM
  3. Laser cutting Machines
    By Want2build1 in forum Laser Machines & Building
    Last Post: 13-05-2014, 01:58 PM
  4. laser cutting ally plate
    By i2i in forum Tool & Tooling Technology
    Last Post: 21-02-2013, 08:47 AM
  5. Laser cutting 10mm acrylic?
    By camhguh in forum Laser Machines & Building
    Last Post: 04-09-2012, 12:51 AM
