  1. #3
    I use the 20mm Hiwin rail and had to grind the allen bolt heads a little so they can sunk in the rails with out problem, I know it is time consuming but i couldn't find bolts with the proper head diameter to drop in there .If you look close at the photo, I place the bolt in the chock of a cordless drill and spin it, while I push it on the grinding wheel, this make the bolt head diameter to be evenly grind.
  2. The Following User Says Thank You to Nickhofen For This Useful Post:
  1. Linear rail question
    By Nr1madman in forum Rails, Guideways & Bearings
    Last Post: 24-06-2017, 05:07 PM
  2. Linear rail advice
    By Darren in forum Rails, Guideways & Bearings
    Last Post: 09-04-2016, 11:15 PM
  3. Best Linear rail mounting set up
    By j2sip in forum Rails, Guideways & Bearings
    Last Post: 19-07-2014, 12:00 AM
  4. Open Rail, open source linear rail?
    By Musht in forum Open Source Designs & Plans
    Last Post: 15-06-2012, 12:21 PM
  5. FOR SALE: Linear rail and bearing
    By black5f in forum Items For Sale
    Last Post: 02-07-2010, 07:23 PM
