  1. #9
    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Chain calculations are the same as rack and pinion.
    Multiply the number of teeth on the sprocket, by the chain pitch, and it gives you distance per revolution of the sprocket.
    Then dived the number of steps it takes to spin the sprocket one revolution, which for direct drive with a standard stepper motor is 200 times the microstep setting, by the distance.
    So if you've got a 10t sprocket with a 1/2" pitch chain, it'll move 5" or 127mm per rev.
    Paired to a standard stepper motor with 8 microstep setting, gives 1600 steps needed per rev.
    So 1600/127 gives 12.594 steps per mm.
  1. Running CNC Router at 25mtr/minute
    By kmeshal9 in forum Gantry/Router Machines & Building
    Last Post: 02-08-2017, 10:20 AM
  2. Running a three phase router/mill on a generator?
    By gavztheouch in forum General Electronics
    Last Post: 19-02-2013, 12:39 PM
  3. axis not moving when running code
    By geny in forum Computer Software
    Last Post: 21-10-2012, 08:02 PM
  4. Running 4 axis from a ps806 or sps705 psu
    By jonbabbz in forum General Electronics
    Last Post: 14-07-2012, 09:50 AM
  5. 4th Axis running as CNC lathe using milling machine
    By Jonathan in forum Milling Machines, Builds & Conversions
    Last Post: 21-08-2011, 10:34 AM
