    I've got two different brands of 15mm linear profile rail (one Chinese import, one SBC Linear). Both have identical mounting holes that are 4.5mm dia. with a countersunk hole for the bolt head 7.5mm dia.
    I'm not sure what bolts I am supposed to use here?
    M4 would fit through the hole, but all M4 bolts with a countersink are 8mm dia. on the head so they don't fit. An M4 cap head would fit the hole but it doesn't seem right to use that on a countersunk hole because the contact patch will only be on the edge on the head.
    Am I supposed to use some kind of imperial size?
    Thanks!
    Quote Originally Posted by Tenson View Post
    Thanks!
    15mm I assume is Hiwin style rail, I have original and clone rail and both take M4 A2 stainless steel bolts.
    This is my clone rail
    https://www.ebay.co.uk/itm/15-1500mm...e/202182780858
    I use the 20mm Hiwin rail and had to grind the allen bolt heads a little so they can sunk in the rails with out problem, I know it is time consuming but i couldn't find bolts with the proper head diameter to drop in there .If you look close at the photo, I place the bolt in the chock of a cordless drill and spin it, while I push it on the grinding wheel, this make the bolt head diameter to be evenly grind.
  4. The Following User Says Thank You to Nickhofen For This Useful Post:
  5. #4
    That's interesting, thanks!
    Here is a photo of one rail (click to biggy). I don't know if you can tell that the bottom of the hole is not 100% flat, it has a very gentle chamfer, like it was drilled rather than milled out with a flat bottom end-mill. I think it is less steep than a standard screw countersink, but also not 100% flat.
    I think what I'll do is just use a soft washer under the screw head to allow it to seat nicely.
  6. #5
    The holes are not countersunk. Use standard 4mm socket head cap screws.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  1. Linear rail question
    By Nr1madman in forum Rails, Guideways & Bearings
    Last Post: 24-06-2017, 05:07 PM
  2. Linear rail advice
    By Darren in forum Rails, Guideways & Bearings
    Last Post: 09-04-2016, 11:15 PM
  3. Best Linear rail mounting set up
    By j2sip in forum Rails, Guideways & Bearings
    Last Post: 19-07-2014, 12:00 AM
  4. Open Rail, open source linear rail?
    By Musht in forum Open Source Designs & Plans
    Last Post: 15-06-2012, 12:21 PM
  5. FOR SALE: Linear rail and bearing
    By black5f in forum Items For Sale
    Last Post: 02-07-2010, 07:23 PM
