I have a 6040Z 4 axis machine, which has worked well for the past year or so. I decided it was time I controlled the spindle via Mach3, but am having problems.
The control box has JMC 2M542-06 drivers for the X,Y and Z axis and a small generic one for the A axis, with a JP-845 four axis control board. All four axis work great, no problems there, and a Nowforever EN100S2R2B VFD.
The VFD connections I would use are X1 - Fwd control, AN1 - 0-10V for speed contol and COM
I have two different BoB's that I could use;
The JP-845 (image attached) has an unused PWM out socket on the board and what appear to be two relay outputs. The PWM pins are unmarked, and with a DMM I have found two of the pins have a constant 5V across them, while the other two don't seem to do anything. The relay pins are marked No.1, COM, No.2, COM.
No matter how I connect the pins up, I cannot get this to work - the speed of the spindle is not controlled by inputs from Mach3, and the spindle is constantly energised.
I cannot find any info regarding this Bob on the net.
The other is a generic 5 axis BoB (image attached). I have connected this up, and everything works except the spindle control. I have the AN1 0-10V connected to the + pin on the board and the COM to the GND. The X1 (FWD) pin is connected to pin 17 on the board.
Now, this is where I am stuck, and probably being really bone - I don't know if I need the relay jumper on or not and, in fact, whether this is the correct way to do it. I have read several posts where people have linked to this second board, saying they use them, but there are no connection details/
Could someone help me out with this please, I'm going nuts!
