08-03-2018 #2
Ade,
You might find that repairing it is cost prohibitive. If I was in your shoes, I'd consider getting a replacement Servo Drive / Motor (400 W) from a range of different suppliers and changing out the Z axis.
The Y Axis motor is difficult to work with (space). The X is fairly easy but if it was me, Id want to keep X and Y the same motors. The Z axis is obviously very different and the motor bracket is fairly easy to modify. You can easily take a plate and modify and then once your machine runs, mill a new one or give me a drawing and I can do one for you.
Charl
Which metal would flex more?
By PaisleyPCdoctor in forum Milling Machines, Builds & ConversionsReplies: 29Last Post: 25-02-2018, 04:29 PM -
Need to get a Baldor F391 board scematic diagram.
By mike dempsey in forum General DiscussionReplies: 0Last Post: 12-01-2018, 06:30 PM -
CSMIO/IP-M with baldor smartstep/3
By Benja in forum Denford MillsReplies: 11Last Post: 03-07-2017, 12:44 PM -
RFQ: laser cut - very simple rectangular parts, PTFE and other flex plastics
By dsc in forum Projects, Jobs & RequestsReplies: 0Last Post: 19-06-2015, 12:59 AM -
chain drive
By jonm in forum Linear & Rotary MotionReplies: 9Last Post: 07-03-2010, 02:36 PM
