    MRob's Avatar
    Lives in Eastbourne, United Kingdom. Last Activity: 25-06-2018 Has been a member for 6-7 years. Has a total post count of 9.
    Hi folks!
    So I have no experience making CNC machines, alas that wasnt a part of mechanical engineering when I went to uni, and I am looking to build myself a CNC wood lathe. But because I have lots of ideas for more complex products, and have a bad habit of biting off more than I can chew, I am intending to make it a 4 axis lathe / carving machine. Preferably with laser engraving to boot. The 4th axis can be indexed - I shouldnt need continuous, and I am semi-confident I can figure out the mechanical aspects of the design, plus I have a lot of experience in wood turning. When I comes to the electronics and programming though, I am... more shaky. I'll be doing mostly thin spindles up to 50cm long but want to be able to come in and do bowls and the like as well. Am intending to use Fusion 360 to spit out the code, and CAD is pretty much second nature to me, but I really am clueless when it comes to the electronics and putting it all together into a working package.
    - So, this is a big project, and question is - in my shoes, where would you direct your time for research? I am thinking of doing a small, almost toy sized version with 3d printed parts etc just to test out the concepts and get used to it all first, before creating the final build, does that sound reasonable, and how big a project would you say this really is? Like, big or huge?? Any other advice much appreciated!
    As a PS, on the mechanical side, when it comes to hitting 3500rpm, being able to turn bowls and goblets, but also being able to do precise c axis movements, I figure I'm going to need a beefy motor and a strong stepper, with only one connected at a time. So each on its own individual bed, moving in and out to connect up with couplers etc. But that seems... very inelegant. Do you know a better way?
    Thanks for your time!
    Something which sprang to mind for your PS is engaging the stepper with a clutch with interlocks to cut power to the spindle motor before the clutch can be engaged, especially easy if your stepper is driving the head through a belt as the driven pulley can be on bearings and run freely with the clutch disengaged.
    MRob's Avatar
    Thanks for the reply - I did look into whether there were any off the shelf CNC clutch mechanisms that I could buy but couldnt find anything. I mean I could probably design something, or use e.g. lawn mower clutches but it is still essentially using steppers to mechanically engage each drive, one at a time. Which I can do, I just thought maybe there was another way! The only alternative that I saw elsewhere, was a suggestion to use a variable reluctance stepper, which is happy to freewheel, but my inclination would still be to disengage the main motor when the stepper is active to reduce mass being driven and backlash. At which point I might as well put both drives on a clutch. Perhaps I am being over the top with it though, and over-thinking the problem? Anyway, the interlock is an interesting idea, I hadnt thought of that!
    In that case a DC Servo with encoder might make more sense, then you can run it as a positional axis or at a set speed.
    MRob's Avatar
    I looked into servos before, but the combination of speed (3500rpm), power (500W+ ideally) and high accuracy together in one package seemed like a stretch, my concern was it would be always be inferior in one area - or least without paying an arm and a leg, and then adding the control complexity on top... But perhaps I just gave up too soon, I'll have another look into it, thanks.
    EDIT yeah definately gave up too soon, can get for £400 or so, much better option.
    Lives in East Lothian, United Kingdom. Last Activity: 2 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    There's a reason why lathes with live tooling have huge horse power motors. It's not that you're ever likely to use 30+hp while turning, it's so they still have enough torque to maintain a stationary position.
    Given you're working with wood, the forces involved shouldn't be as high as metal, but you can still calculate the potential forces. If you know how big your live tooling motor is, and how much torque it can produce, you can then calculate the potential maximum force on the cutter edge. You can then take that force and calculate the torque the spindle needs to produce to hold steady (plus add a safety margin).
    For ideas, search out the In-turn (there's a huge build/development thread on the mach support forum), which is a dual speed 4th axis add-on.
    However, having a suitably geared motor only connect for positional work is a valid option. At low speed, having the high speed motor still connected shouldn't be a problem. It will add a bit more inertia, but I'd be looking at keeping the low speed at under 60rpm, so that additional inertia is going to be minimal, and reduces the level of complexity you need for changing speed.
    The big problem is how you handle backlash in your positional motor drive system.
  1. Yet Another Noob. Looking for Kit or Guide
    By RatherBeMaking in forum Gantry/Router Machines & Building
    Last Post: 09-04-2015, 09:52 AM
  2. NEW MEMBER: Noob
    By Karl CNC Scenex in forum New Member Introductions
    Last Post: 20-12-2012, 11:16 AM
  3. NEW MEMBER: Hi from a CNC noob, London
    By masonman in forum New Member Introductions
    Last Post: 17-09-2010, 09:57 PM
  4. NEW MEMBER: noob log in...
    By flez1966 in forum New Member Introductions
    Last Post: 12-10-2009, 06:33 AM
  5. NEW MEMBER: Another Noob!
    By Jaff in forum New Member Introductions
    Last Post: 16-09-2009, 10:46 PM
