Bit of an old thread bump, but with regards to changing the tool angle, I can do this in Fusion for creating a cut, and I think I can add manual code for tool changes as well. I am tending towards LinuxCNC for its expandability and the number of axis it can deal with (if I want to add e.g. laser engraver later) - and also the price is right :). Hopefully I can do a macro or other Linuxcnc equivalent to handle the "tool change". Then perhaps I can also add in z and x offsets to position the cutter correctly as part of the macro, although I'm still a little fuzzy on that. Hell am still pretty fuzzy on all of this actually, but I am learning!
Physically the tool change will be like a horizontal tool turret, with say only 3 or 4 actual tools on it (e.g. rough, final cut, and parting), but with the ability to lock at other angles. If done like a proper tool turret I could have e.g. 30 degree increments, but I could probably just make a rotary table with a brake on it and a geared stepper, should work - so long as it is rigid enough, and I'm pretty sure I can figure that out.
Does this all sound reasonable?!Last edited by MRob; 29-03-2018 at 05:10 PM.
29-03-2018 #2
I'd research lathe tool turrets some more, there's a reason all the commercial ones don't work like that, if you need to centre drill, pilot drill and finish drill your bore then ream it how will you do that and face the end and put a shoulder on the OD and part off?
And that's a pretty simple part! Try to avoid designing something that is NBG as soon as it's finished.You think that's too expensive? You're not a Model Engineer are you? :D
29-03-2018 #3
A simple part for metal machining perhaps :). But I am turning wood, I really dont need all those functions! Here's a vid that is pretty close to what I want:
https://www.youtube.com/watch?v=GB5fMNte844
I guess the reason people do vertical tool turrets is to fit more tools in there, but if I am OK limiting myself to 3 or 4 its not really an issue. And I get to change the angle of approach for the tools, which is pretty important for me.
Yet Another Noob. Looking for Kit or Guide
By RatherBeMaking in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 09-04-2015, 09:52 AM -
NEW MEMBER: Noob
By Karl CNC Scenex in forum New Member IntroductionsReplies: 7Last Post: 20-12-2012, 11:16 AM -
NEW MEMBER: Hi from a CNC noob, London
By masonman in forum New Member IntroductionsReplies: 1Last Post: 17-09-2010, 09:57 PM -
NEW MEMBER: noob log in...
By flez1966 in forum New Member IntroductionsReplies: 2Last Post: 12-10-2009, 06:33 AM -
NEW MEMBER: Another Noob!
By Jaff in forum New Member IntroductionsReplies: 3Last Post: 16-09-2009, 10:46 PM
