    I'm also a little curious about Mach4, but I'm not even going to ask.....
    Actually think I'll do that if I can find the strength or Will to make the bloody thing work.!!
    Hi Dean
    Sounds like a great idea for a video !
    Do you have a system you can dig out of the skip using a generic breakout board on a parallel port? Would be good entertainment to see it perform when the TIG fires up next door! I guess they've long gone to landfill but had to ask.
    Ye sure I've got PC kicking around that could try that with PP and Basic BOB. . . . Forget Tig bloody radio will kill a PP & cheap BOB if wind's blowing in right direction. . . Esp if playing Radio1 . . .Lol
    only frightened of the unknown
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 12 Hours Ago Has a total post count of 1,653. Received thanks 115 times, giving thanks to others 71 times.
    Im now running Centroid Acorn on my lathe - so happy to provide any feedback / experience based on this if it helps. Fairly familiar with Mach 3 and a few of the controllers listed above.
  5. #15
    Quote Originally Posted by audioandy View Post
    Bloody hell it surfaces from the deep...
  6. #16
    Making a comeback Dean,got to use some of the accumulated bits in my garage. Good to see you are still keeping the forum in check
    Sent from my SM-G920F using Tapatalk
  7. #17
    About bloody time not good for man sat around playing with them pussy's all day..
  8. #18
  9. #19
    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 15 Hours Ago Has been a member for 9-10 years. Has a total post count of 300. Received thanks 28 times, giving thanks to others 13 times.
    Chaz,
    Now you have been using Acorn a while any advice / feedback on it's setting up and use, I am interested how you find it as I have just ordered one.
    I have an Orac cnc lathe that I want to convert to use with the Acorn.
    Phill
  10. #20
    Chaz's Avatar
    Chaz,
    Phill
    Hi Phill,
    Ive not done a lot with it as yet as Ive had to solve some other issues.
    The platform is good and stable. Inherently more so than Mach which solves many issues. Support however is good and its based on a known established 'standard'.
    I needed to forget about Mach as you cannot always apply the same thinking (steps / mm etc). Its a different approach, but certainly not impossible. Ive done a lathe, Ill do my next machine with Acorn too and perhaps one day convert my Thor, but Ive invested heavily and the wiring / servos only work on CS Labs.
    One thing, get a decent PC for Acorn. They recommend following a certain spec with Win 10. I had other machines (spec was too low) and I had a spindle issue. We couldnt point it to the low spec machines, but could be.
    Ive managed to get my ATC to work, took some effort.
    The PLC is powerful but you need to understand their code and/or get help.
    Depending on how complex you need to do, it can handle it. Its a pity its only 4 axis and certainly more inputs / outputs would be nice but things can be done via their PLC logic.
    I bought on a Sunday night, received Wednesday. You will be nailed import cost but its not bad in reality (they did a recent price drop when they sold 1000 units).
    Certainly recommended. The touchscreen implementation is great, so expect to need one of them too.
    Chaz
  11. The Following User Says Thank You to Chaz For This Useful Post:
  1. Comparison between mechanical designs of cnc machines
    By ammaratef45 in forum Machine Discussion
    Last Post: 19-07-2016, 10:48 PM
  2. Replies: 5
    Last Post: 20-02-2014, 12:15 AM
  3. SBR v TBR - Comparison
    By Karl in forum Rails, Guideways & Bearings
    Last Post: 30-05-2012, 12:02 PM
  4. Breakout Board Comparison
    By 200thhorseman in forum Gantry/Router Machines & Building
    Last Post: 27-03-2012, 12:28 AM
  5. Controller Box
    By M250cnc in forum Motor Drivers & Controllers
    Last Post: 21-11-2010, 01:34 AM
