Thread: Controller Comparison
18-03-2018 #1
Ok well this as been on my mind to do this for while now so what you all think.?
I've got reasonable collection of popular Controllers laying around now so thinking to do a comparison test (video)on same machine with same drives etc.
This will be spare Router I've got kicking about so will obviously be Router biased. Could be servo or stepper driven not sure yet.
The controllers I've got are.
Cslabs IP-M, IP-S, IP-A (IP-A might be separate test on servo motor on bench) (Mach3 and Simcnc only)
UC300USB with PMDX126 BOB (Mach3 or UCCNC)
UC300ETH with UB1 BOB
Centroid Acorn (CNC12 Mill only)
Smooth stepper ESS, USB with PMDX 126 BOB (Mach3 only)
Pokeys 57U, 57CNC (mach3 only)
CNCUSB Mk3/4 (Planet CNC)
DDSCV1.1 3 4 axis offline motion controller
Might Knock up a Linux cnc with Mesa cards (when get them)
Obviously this will take a while to setup and done between health/work commitments plus seen as it's -4c in workshop won't be until warmed up a bit so don't hold your breath's or put off buying for current project you got going on. However it will happen, might just take me couple months to get all together.
So if you lads have any requests to see any specific comparison etc or have any Code you want testing then shout up.Last edited by JAZZCNC; 18-03-2018 at 03:34 PM.
18-03-2018 #2
Ok I bought 2kilos pop corn and waiting! :-)
18-03-2018 #3
19-03-2018 #4
Looking forward to it! I have a spare arduino with cnc shield you can have if you want to try that as well, will interface with stepper drivers. I can send it out flashed with grbl and ready to go.
I'd like to see the same piece cut with multiple tool changes on all the controllers, set up as close as possible to each other to see if there's a difference in quality and speed.
I have no doubt grbl won't perform close to the other controllers but it's less than £15 lol so would be interesting to see what you could do with it ;) Especially as you'll have the best router grbl has ever been connected to lol.Last edited by Desertboy; 19-03-2018 at 06:32 AM.
19-03-2018 #5
19-03-2018 #6https://emvioeng.com
19-03-2018 #7
I'm curious about differences in high speed motion between the acorn and UCCNC.
Not interested in Mach3 at all at this point (even though I'm still using it).Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
19-03-2018 #8
19-03-2018 #9
I'm also a little curious about Mach4, but I'm not even going to ask.....
Gerry
19-03-2018 #10
Hi Dean
Sounds like a great idea for a video !
Do you have a system you can dig out of the skip using a generic breakout board on a parallel port? Would be good entertainment to see it perform when the TIG fires up next door! I guess they've long gone to landfill but had to ask.
Comparison between mechanical designs of cnc machines
By ammaratef45 in forum Machine DiscussionReplies: 6Last Post: 19-07-2016, 10:48 PM -
Profiled rails - Installation guidelines and manufacturer comparison chart
By mocha in forum Rails, Guideways & BearingsReplies: 5Last Post: 20-02-2014, 12:15 AM -
SBR v TBR - Comparison
By Karl in forum Rails, Guideways & BearingsReplies: 0Last Post: 30-05-2012, 12:02 PM -
Breakout Board Comparison
By 200thhorseman in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 27-03-2012, 12:28 AM -
Controller Box
By M250cnc in forum Motor Drivers & ControllersReplies: 1Last Post: 21-11-2010, 01:34 AM
