Page 4 of 6 FirstFirst ... 23456 LastLast
  1. #31
    Quote Originally Posted by GrahamWhite View Post
    How does someone with absolutely no knowledge of electrics design or layout the insides!??
    Ok simple rule of thumb with layout is to keep mains voltage items/cables far away from Signal wires much as possible. Obviously at some points they will have to meet but reducing how close the wires and components come together will lower chances of electrical noise interference.
    Regards the wiring design then just keep it simple don't go too crazy with the safety side. Many folks go way OTT with safety buying expensive Safety Relays when all that is needed is simple Relay driven latching E-stop circuit.
    Ideally, you want to use 24Vdc for the Safety circuit and limit switches,relays etc as this gives greater immunity from noise interference. Can use 12V but 24V is best, avoid using 5V if possible.
    Also, for new builder it's a good idea to build control in stages rather than wiring every thing at once only to find out something wrong at switch on and then struggle to diagnose where gone wrong.
    If you give detailed list of all the stuff you have I don't mind drawing you up diagram.
  2. #32
    That would be great cheers :)
    So far I have..
    4 drivers https://www.omc-stepperonline.com/st...or-dm860t.html
    Breakout board https://www.omc-stepperonline.com/st...kit-st-v2.html
    UC300 eth - 5lpt http://cncdrive.com/UC300.html
    24v PSU
    5v PSU
    toroidal psu with no bridge rectifier or caps as driver accept AC
    stop/start button (1no 1nc) NVR
    emergency stop button
    2.2kw water cooled spindle with VFD
    water pump for spindle
    big enclosure
    Still to buy - control cable?
    limit/home switches- do you have them at each end or just for home position?
  3. #33
    My preference is to combine the Home-limit switches and have the switch travel with the axis sensing/hitting fixed targets at each end. This way fewer switches to go wrong and less wires running around machine.
    Will you be using Micro switch type or proximity.? My pref is proximity NPN type.
  4. #34
    just had a look and the proximity NPN type are cheap enough and I like the idea of less switches=less cost! lol
  5. #35
    Ok but due to BOB having a common Ground you'll have to go with PNP.
  6. #36
    Ok thanks- I'll keep an eye out for that when I order!
  7. #37
    So I've learned another lesson on ordering from the USA- again the metric /imperial beast raises it's head again in the form of spur gears on the reduction drives!
    And with a local company wanting nearly £100 each to machine up the appropriate MOD 1.0 spur replacement, I'm having to go for an off the shelf spur, have it bored out and get a collar turned up to fit it instead!
  8. #38
    So decided it was time to start laying out the control box
    I'm gathering you try to keep the mains power stuff away from signal stuff as best as possible.
    Want to try and keep VFD in there as well as I seem to have enough space ....unless I'm missing some bits! nothing big I hope!
    Been looking at control cable and wondered how expensive you need to go?
    4 core 0.75mm screened Flexible cable £4.13 per meter https://www.rapidonline.com/lappkabe...0-75mm-63-4774
    or cheaper 809 cy flex at £2.98 per meter https://www.rapidonline.com/lappkabe...0-75mm-63-4331
    Do I run the home/limit switches(magnetic PNP) in 3 core- screened also?
  9. #39
    Check out if reichelt will ship to UK.
    For cy 4x1mm2 i ended up paying 1.20 €/mtr for 50 meters delivered at my house.
    Grtz Bert
  10. #40
    At 1.20 euros a meter was that for chain flex? I've seen prices for cy shielded from £0.60p per m but it doesn't suggest constant bending i.e for chain drive
    I found this company at £1.94 per m for chain flex https://www.tme.eu/gb/details/cf881....shielded/igus/
    or is the chain flex over the top?? and standard CY shielded fine?
  1. NEW MEMBER: New Build of a Joe's CNC Hybrid R&P 8x4
    By GrahamWhite in forum New Member Introductions
    Last Post: 20-03-2018, 07:16 PM
  2. BUILD LOG: Plans for new build
    By jas46 in forum DIY Router Build Logs
    Last Post: 21-09-2015, 02:17 PM
  3. MDF CNC Router plans / parts for home build beginners
    By HiltonSteve in forum Gantry/Router Machines & Building
    Last Post: 10-06-2012, 02:33 PM
  4. Trying to find a kit or plans to build.
    By don_jarr in forum Gantry/Router Machines & Building
    Last Post: 16-06-2011, 04:28 PM
  5. NEW MEMBER: Hi from rainy York - build plans/questions
    By bikepete in forum New Member Introductions
    Last Post: 11-10-2009, 07:43 AM
