I bought this. 1 size fits all
1mm2
https://m.reichelt.de/OeLFLEX-CLASSI...1&trstct=pos_2
I believe it says class 5 flex 20x OD bending property.
Non moving bending property 6x OD
https://reichelt.de
16-05-2018 #2
09-06-2018 #3
So after a bit of a gap, the control panel has gone away for a first fix so to speak.
A friend of mine who deals with that sort of stuff has very kindly offered to sort it out :)as in return he needed someone with a 3d printer to print some adapters for his RC car wheels :)
Should come back with some neat spaghetti I hope!
18-06-2018 #4
So panel is back and thanks to Jazz for the wiring diagram, my mate sorted it out a treat- a million miles better than my effort would have achieved !!
Mounted on the wall and fitted the fans to the front panel.
I added a start/stop button by mistake -actually not needed- so i'll probably turn it into a window so I can see the VFD front.
I've been told I can wire up the other things but I'm not allowed to turn it on! lol or even plug it in!!
18-06-2018 #5
Hi Graham your mates made a nice job of the wiring etc but you need to re-route and separate some of the wires otherwise your probably going to get false E-stops etc from back EMF.
If he's general sparky he'll not be used to dealing with machine controls where tieing or routing together signal wires with high voltage wires is a BIG No-no.
I've circled the picture where I see potential trouble areas because signal wires are tie wrapped to high voltage or too close to VFD which gives off high EMF.
05-07-2018 #6
So a bit more work done on the electrics
Drag chains fitted
Leaves a nice pile to sort out :)
A quick route to the control box
And then some cutting, soldering and attaching...
Still have the drives unplugged as not had the nerve to plug it in yet, need a quick recheck first.
Whats the next step ? attach to computer and switch it on ? or are there some other steps first ?
Still got to re-route some wires in case it causes issues.
12-07-2018 #7
Right so it's ALIVE!!
Please excuse the mess! :(
https://www.youtube.com/watch?v=Ru4H7zRt0lM
Finally gave up and bought the UCCNC software, and got all the axis jogging with the Y and A slaved :)
So I thought I'd try and setup the home limits.
Lucked out on the Z nearly first go.
Trying to set the X up- turned on pin 13 - I jogged it to the stop bolt (proximity limits) and the light came on but about 4or 5 seconds later a plume of smoke came out of the back of the limit!!
Cut off and refitted a new one- thought it may just have been dodgy … same again!
That's why I think I lucked out on the Z -I hit home and when it reaches it the light flicked on and the it backed off and went off.
Any ideas guys
The limits are PNP NO upto 36v- im using 24v- running brown to 24v ,blue to 0v and black to sensor pin on BOBLast edited by GrahamWhite; 12-07-2018 at 08:58 PM.
NEW MEMBER: New Build of a Joe's CNC Hybrid R&P 8x4
By GrahamWhite in forum New Member IntroductionsReplies: 7Last Post: 20-03-2018, 07:16 PM -
BUILD LOG: Plans for new build
By jas46 in forum DIY Router Build LogsReplies: 0Last Post: 21-09-2015, 02:17 PM -
MDF CNC Router plans / parts for home build beginners
By HiltonSteve in forum Gantry/Router Machines & BuildingReplies: 81Last Post: 10-06-2012, 02:33 PM -
Trying to find a kit or plans to build.
By don_jarr in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 16-06-2011, 04:28 PM -
NEW MEMBER: Hi from rainy York - build plans/questions
By bikepete in forum New Member IntroductionsReplies: 13Last Post: 11-10-2009, 07:43 AM
