There's massive difference even with 15mm but that said have you checked out prices from China rather than UK. You'll get them lot cheaper than in UK.
Also if your budget is tight look for supported round rail. It's good compromise and still light years ahead of v bearings.
19-03-2018 #2
Stay away from v bearings. They are a pain in the bum. Seen them fitted to a few machines I used to work on in the past and they were always needing adjusted to work properly.
20-03-2018 #3
You'll most likely find 15mm linear rail has a higher load rating than V bearings.
15mm rail is more than capable of handling most CNC machines, it's just larger rail is a bit easier to mount (15mm typically needs M4 bolts, which require more care than M5 or M6).
I've just checked the load rating for some 15mm rail, and it is around 10kN depending on the carriage used. That's roughly the same as sitting a tonne on each carriage. Off course that relies on the rails being suitably mounted.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
What is the best way to mark out for bearing blocks and linear rails?
By gavztheouch in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 18-05-2014, 02:08 PM -
balscrews from linear motion bearing and rails, question about sizing
By Boyan Silyavski in forum Lead Screws, Nuts & SupportsReplies: 3Last Post: 18-08-2013, 08:11 PM -
Round rails & bearing fit?
By Peter. in forum Rails, Guideways & BearingsReplies: 2Last Post: 11-10-2012, 06:59 AM -
FOR SALE: ballscrews, supported linear rails, linear bearings, complete kit. for sale
By cutter in forum Items For SaleReplies: 0Last Post: 04-12-2011, 03:23 PM -
THK linear bearing rails
By Tonyel in forum Rails, Guideways & BearingsReplies: 0Last Post: 01-11-2008, 03:21 PM
