    Hi all I have set up my CNC 6040 machine now and have an issue with the motors jamming whilst manually moving them (jams and makes a high pitched noise)
    To my understanding this could be my setup of the motors but when I initially got my machine moving yesterday I moved all the motors fine with no issue so not 100% sure.
    At the moment I am just copying what others are telling me to put in mach3 settings but I would like to know what I am inputting and why so that I can better understand my machine.
    Is there anywhere particular I can look up for research material or download a book etc. and or is there sites to avoid as known for giving incorrect information?
    If you are interested my settings on the motors are on the attachment, I am not sure what else you require other than I am using 220v and all three motors have jammed.
    PS the temperature in my garage has dropped to 3 degrees I do not know if this makes any difference in the structure/performance of the machine itself.
    Kind Regards Graham
  1. Fill in my knowledge gap :)
    By Davek0974 in forum CamBam
    Last Post: 02-02-2017, 02:55 PM
  2. Power supply understanding
    By smeg up in forum General Electronics
    Last Post: 10-02-2015, 07:07 PM
  3. Replies: 1
    Last Post: 14-07-2014, 03:28 PM
  4. Understanding the bearing block
    By Rogue in forum Rails, Guideways & Bearings
    Last Post: 28-08-2011, 03:14 PM
  5. Some great DIY clamping setups
    By Yohudi in forum Computer Software
    Last Post: 22-01-2009, 06:54 PM
