Thread: CNC3040 Z Probe problem.
22-03-2018 #1
I wonder if anyone can help with a z probe issue I have.
I have a Chinese CNC3040 cnc machine, with a arduino to db25 adapter - basically converting grbl to mach3.
I have the A5 and GND pins wired for a z probe in GRBL.
I am using BCNC software and when i short the 2 z probe wires - I get confirmation that the zero point has been reached.
When I carry out a z probe routine on the actual cnc (gnd to chassis and z probe to milling bit) - the probe stops short of the zero point and I have to run the routine 2 or 3 times before it actually get to the correct zero point.
I have checked all the wiring on my 3040 - as they are known for bad GND`s. I have also checked the continuity from the chassis to the milling bit to make sure its open circuit.
Does anyone have any ideas how to solve this problem?
Do I need a resistor or capacitor to smooth the z probe line?
Many thanks in advance.
Iain
FOR SALE: CNC3040 with PC & Monitor (Mach3)
By jeboa in forum Items For SaleReplies: 11Last Post: 10-02-2024, 12:21 AM -
Weird Mach3 + CSMIO/IP-M Probe Problem
By matt-b2 in forum General DiscussionReplies: 24Last Post: 11-07-2019, 01:05 PM -
tool probe problem
By johngoodrich in forum General ElectronicsReplies: 7Last Post: 18-04-2017, 08:08 PM -
Edge Probe + tool length probe on same input
By Noplace in forum General ElectronicsReplies: 1Last Post: 18-06-2016, 11:12 AM -
CNC3040 help please
By craigrobbo in forum General DiscussionReplies: 2Last Post: 20-12-2014, 10:40 AM
