Thread: CNC 6040z USB z-axis
23-03-2018 #6
It's USB, you say, so it can't be a parallel port or cable problem. As long as Mach3 has the correct pin and you are also looking at the correct pin (not always trivial - I use a CSMIO controller and the pin numbers in Mach3 are not the same as the terminal numbers on the controller!) then it does indeed sound like a controller issue. Good luck!
You could also try JazzCNC's tip - it's not clear why this would work, but it is a Chinese controller so logic doesn't always play a role
6040Z USB CNC - USB port not recognised.
By Roy in forum Chinese MachinesReplies: 9Last Post: 23-05-2021, 10:04 AM -
B Axis indexing and easy workflow for repetitive cuts 4-axis
By deemoss in forum General DiscussionReplies: 1Last Post: 21-06-2017, 12:34 PM -
Engraving small font - the bit digs deeper and deeper as the job goes on. 6040z
By xoneeleven in forum Chinese MachinesReplies: 46Last Post: 26-04-2016, 12:06 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
