Hi Clive
I presume they sent it as the cable from the steppers to the control box, I`ll have to check that as they have only sent some parts for the controller but there must be 10 or 15 meters of cable. When I get home i'll check on my receipt to see if there is anything else coming. Would the 0.75 wire you recommended be thick enough for the 4.2 amp motors.
Cheers again
Andrew
Andrew where did I recommend 0.75mm cable ? I said 0.5mm is fine for signal wires but you will need 0.75mm for steppers (CY 4 is good ) as Jazz said. the screen on the CY cable needs to be grounded to the star point in the control box. ( at one end only)
A star point is just a connection point where all the grounds connect to in one place (it is to stop current loops)..Clive
27-03-2018 #3
Hi clive.
Errr sorry Clive I got you mixed up with Jazz, i'm on 3 weeks of antibiotics, it tends to scramble the brain a bit.
Reply 4 mentioned 0.75.
cheers.
AndrewLast edited by the great waldo; 27-03-2018 at 02:05 PM.
WANTED: Conqueror Design stepper driver or stepper conversion board
By pistolknight in forum Items WantedReplies: 1Last Post: 25-05-2019, 11:57 AM -
Control panel wire gauge question?
By Dwayne Dibbley in forum General ElectronicsReplies: 22Last Post: 15-04-2015, 07:21 PM -
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
3 wire stepper motor drivers?
By m_c in forum Stepper & Servo MotorsReplies: 0Last Post: 17-08-2013, 10:01 PM
