Page 1 of 3 123 LastLast
    Hello all
    I finally gave up the idea of upgrading my old makko 850 with acme threads and went for one of these https://www.sorotec.de/shop/Portal-m...-DIY-4863.html
    I am in the process of wiring up the control box and will be basing it on this wiring diagram http://www.sorotec.de/webshop/Bedien...uerung_pro.pdf I am using leadshine em705 drivers and was wondering if one has to use screened cable from the driver to the socket for the stepper on the case or is normal stranded wire ok? thanks in advance.
    cheers
    Andrew
    Quote Originally Posted by the great waldo View Post
    cheers
    Andrew
    Ideally you would use Screened cable but if it's short run and not located near high voltage wires ie: Mains voltage then you'll be fine.
    Hi Jazz.
    Thanks for the info it. It is a short run but i'll go for screened wire. Any idea about wire specs on the wire? The steppers are just over 4amps https://www.sorotec.de/shop/Stepping...M-Nanotec.html tia.
    Cheers.
    Andrew
    Hi Jazz.
    Cheers.
    Andrew
    0.75mm2 CY cable is what you need.
    Hi Jazz.
    Thank you for the info and your time.
    Cheers.
    Andrew
    Hi Jazz
    One last question (I promise) regarding wire specs, Sorotec sent me 0.5 mm wire with the set, is it worth the effort to go for 0.75mm wire. I'll stick with this machine until i'm pushing up the daisys so I don't mind putting in a bit of effort in getting things right now.
    Cheers.
    Andrew
    Lives in Marple Stockport, United Kingdom. Last Activity: 21 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    It depends where you are using the wire 0.5mm is fine for signal wires.
    Hi Clive
    I presume they sent it as the cable from the steppers to the control box, I`ll have to check that as they have only sent some parts for the controller but there must be 10 or 15 meters of cable. When I get home i'll check on my receipt to see if there is anything else coming. Would the 0.75 wire you recommended be thick enough for the 4.2 amp motors.
    Cheers again
    Andrew
    Hi Clive
    Cheers again
    Andrew
    Andrew where did I recommend 0.75mm cable ? I said 0.5mm is fine for signal wires but you will need 0.75mm for steppers (CY 4 is good ) as Jazz said. the screen on the CY cable needs to be grounded to the star point in the control box. ( at one end only)
    A star point is just a connection point where all the grounds connect to in one place (it is to stop current loops)
    Hi clive.
    Errr sorry Clive I got you mixed up with Jazz, i'm on 3 weeks of antibiotics, it tends to scramble the brain a bit.
    Reply 4 mentioned 0.75.
    cheers.
    Andrew
  1. WANTED: Conqueror Design stepper driver or stepper conversion board
    By pistolknight in forum Items Wanted
    Last Post: 25-05-2019, 11:57 AM
  2. Control panel wire gauge question?
    By Dwayne Dibbley in forum General Electronics
    Last Post: 15-04-2015, 07:21 PM
  3. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  4. Replies: 1
  5. 3 wire stepper motor drivers?
    Last Post: 17-08-2013, 10:01 PM
