    Interesting design, it is ambitious for a first build!
    If the aluminium pieces you need to machine are small then a mill style is a better option. But if the pieces are fairly large then a router is required but be aware it will not be as stiff as the mill. To maximise the stiffness of the route I would avoid cutting long slots in the bed and gantry frames as this will reduce the stiffness noticeably (from a box to a U channel), and even adding the L bracket will not recover much of it. I wouldn't make that choice just to protect the ballscrews. Go for stiffness in the basic structure first, then add external ballscrews, and then add brush covers over the screws if required.
    15mm rails are a bit small on X and Y, go for 20mm instead. On the Z then 20mm is also fine with 4 rails and 8 carriages. If you drop to 4 rails and 4 carriages (I'm guessing you mean mounted around the lowest part of the Y axis box) it will still function but you will have lost a fair bit of the advantage of the box Z structure. I would say either go all out for 4 rails / 8 carriages, or go for simpler conventional Y and Z, not something in between.
    hello oliv,
    You have a challenging design, yet you should improve your y axis saddle. I will upload some pictures for you to do so.
    First of all for the Y axis : 2 linear rail is not enoughhhhhhhh!!
    Check these symetric structure of Z axis pictures. I suggest you to place 2 rails on each side with different directions.
ID:	24360   Click image for larger version.
Name:	Box in box structure-1.PNG
ID:	24362   Click image for larger version.
Name:	Y axis-1.png
ID:	24363   Click image for larger version.
Name:	HYUNDAI WIA XF6300.png
ID:	24364   Click image for larger version.
Name:	y Axis-2.jpg
ID:	24365   Click image for larger version.
Name:	y-z Axis-1.jpg
  1. BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
  2. Requesting some feedback on steel frame design.
    By Misc in forum Gantry/Router Machines & Building
    Last Post: 15-12-2014, 02:49 PM
  3. BUILD LOG: Design stage of 4030(ish) for wood and plastic
    By andy586 in forum DIY Router Build Logs
    Last Post: 14-11-2013, 10:07 PM
  4. BUILD LOG: Steel/Aluminium design/build, sorta smallish, cuts ali hopefully
    By mart154 in forum DIY Router Build Logs
    Last Post: 19-09-2013, 05:48 PM
  5. Small Mill very early design stage
    By leadinglights in forum Milling Machines, Builds & Conversions
    Last Post: 15-06-2010, 01:05 AM
