Page 7 of 7 FirstFirst ... 567
  1. #61
    As Clive says - a bit of overkill. In theory it should work, and the argument that the UC300ETH (or whatever) will only draw the current that it requires is correct, however, big PSUs like this are sometimes less well regulated when substantially under utilised. Chances are that it will work, but something closer to the requirement of the UC300ETH (and any BOB, limit switch, relays, etc) would be sensible. 2A would be my target for something like this.
  2. #62
    Thanks for the link and the feedback, it's helping a lot in this project. Now I've got a few phone power supplies too, but the one problem is that the one is out putting 5.1 volts rather than the " exact 5 volt maximum." Is that something that should worry me? I know it's sounding a bit picky But it never hurts to ask just in case.
    Thanks again in advance!
    Sent from my Moto G (5) using Tapatalk
  3. #63
    the extra 0.1V from your 5.1V power supply is not a problem
    for 5V logic like the old 74series TTL logic
    the limits for nominal 5V supply voltage is between the 4.75 min and 5.25V max
    for 5V Atmel 8 bit micro controllers like the ATmega8 operating voltage is 4.5V to 5.5V
    John
    PS
    any one know which micro controller has been used for the UC300ETH ?
    Last edited by john swift; 15-05-2019 at 12:18 PM. Reason: add PS - which micro controller
  4. #64
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    As John says, that voltage sounds fine. It could even be your multimeter that's slightly out.
    I would guess the UC300 is using some form of ARM chip, regardless I'd guess whatever chip will be running at 3.3V. Even a few years ago, the vast majority of microcontrollers were running at 3.3V max, with 5V capable ones being a dying breed.
  5. #65
    m_c
    your correct the micro controller is a 3.3V device
    looking at a photo of the UC300 it has a
    MICROCHIP dsPIC33EP256
Name:	UC300 PIC chip.jpg
    from the MICROCHIP web site
    Operating Voltage Range (V)
    3 to 3.6
    the dsPIC33EP256 Input/Output
    • Sink/Source 10 mA on All Pins
    • 5V Tolerant Pins
    • Selectable Open-Drain, Pull-ups and Pull-Downs
    • Up to 5 mA Overvoltage Clamp Current
    • External Interrupts on All I/O pins
    the UC300 board has a 5V supply connector
    so the surface mount device between the 5V supply and PIC
    must be a low drop out 3.3V regulator
    John
  1. CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller
    By dudz in forum CS-Lab (CSMIO)
    Last Post: 02-01-2017, 01:27 AM
  2. BoB Suggestions within UK
    By andy_con in forum General Electronics
    Last Post: 09-05-2016, 10:39 PM
  3. USB/Ethernet controller for Mach3/4 advice
    By paulus.v in forum Control Hardware & Systems
    Last Post: 17-02-2015, 09:37 PM
  4. Boring Bar Suggestions?
    By Washout in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 21-06-2014, 08:59 AM
  5. USB and Ethernet Mach3 motion controller PLCM-E3
    By Purelogic R&D in forum Manufacturer News
    Last Post: 29-12-2012, 09:38 AM
