04-04-2018 #11
No I'm not Kidding and the OP ask's for suggestions for Good drives and to advise he buys old Analog technology is bad advise IMO.
Like I say just because your using them and happy with them doesn't make them good. It just means you don't know any better. You've already proven this by saying you havent used Digital drives so can't possibly know the difference.
Also to claim your machine is fast as it can get and is better than any other stepper machine is just plain ridiculous when your using analog drives with 50Vdc drives. Digital drives running stepper motors with 70Vdc will blow any analog drive with motors running 45Vdc out the water on every level.
Even like for like on voltage Digital drives will make difference to both speed and smoothness.
Regards the Controller making a big difference then your correct. However this is also a area where Digital drives make a huge difference over Analog when not using good motion controller Ie: PP because they handle resonance and lower grade signals so much better.
This isn't about Digital is better just for the sake of it. The truth is, whether you care to accept it or not, is that Digital is better for several reasons and anyone who has had shity Analog drives will tell you this.
CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller
By dudz in forum CS-Lab (CSMIO)Replies: 35Last Post: 02-01-2017, 01:27 AM -
BoB Suggestions within UK
By andy_con in forum General ElectronicsReplies: 9Last Post: 09-05-2016, 10:39 PM -
USB/Ethernet controller for Mach3/4 advice
By paulus.v in forum Control Hardware & SystemsReplies: 17Last Post: 17-02-2015, 09:37 PM -
Boring Bar Suggestions?
By Washout in forum Lathes, Lathe Rebuilding & ConversionsReplies: 10Last Post: 21-06-2014, 08:59 AM -
USB and Ethernet Mach3 motion controller PLCM-E3
By Purelogic R&D in forum Manufacturer NewsReplies: 39Last Post: 29-12-2012, 09:38 AM
