Thread: 3D Soap Dish
Sure - I used a 4mm square end mill for the roughing and a 4mm ball nose for the finishing. In all honesty a 3mm would be better for the finishing pass, but you'd need a long neck/flute or a shaft no thicker than 3mm to avoid rubbing on the steep sides... I may flare out the troughs and the front and rear faces a bit on the newer model to make it a bit easier to cut...
Wal.
Sent from my HTC One M9 using Tapatalk
01-04-2018 #2
Wal I think you have too much time on your hands
02-04-2018 #3
Don't you mean my impeccably clean hands, Clive..?! ;)
Wal.
EDIT: To be honest, whilst seeming a bit self-indulgent, there's a fair bit I'm picking up with regards to how VCarve handles 3D objects - specifically how it cuts 'em. i.e. cutting along the troughs is A LOT quicker, but frustratingly if the 0.3mm step-over falls on an area that it's not allowed to get to the bottom of, it just ignores the bit that hasn't been cut - of course, you can get around it by narrowing the step-over or adjusting the raster angle - both of which increase cutting time, but them's the breaks, I guess. As a side note, I ended up going with a 45° raster angle, which gave me a decent enough finish in the troughs but wasn't ideal on the steep sides - using the 45° angle stressed the tool a fair bit too - leading to this:
02-04-2018 #4
02-04-2018 #5
03-04-2018 #6
04-04-2018 #7
Nice one John - can't wait to see 'em lacquered up! The figuring on the one on the left looks ace.
Wal.
