    Wal's Avatar
    Quote Originally Posted by johngoodrich View Post
    that's awesome. how do you do the infill
    Cheers John.
    I use the 2-part cold enamel available from Cookson Gold. It's good stuff, but needs to be mixed very accurately - particularly when prepping smaller quantities. Two ways of filling - over-fill and sand back to a flush surface, or (slightly trickier) under-fill to get that sunken look. In either case, flash it with a blow torch to remove air bubbles.
    Wal.
    Sent from my HTC One M9 using Tapatalk
  2. The Following 2 Users Say Thank You to Wal For This Useful Post:
  3. #2
    Wal's Avatar
    Apologies for resurrecting this old thread - the original post related to a test piece / prototype. The project sat on the back burner for near enough a couple of years, but a tweaked design eventually came through a month or so ago and I was commissioned to make 15 plaques in total. Managed to get a bit of the process (including the enamelling) recorded, here are a few clips. My favourite bit's got to be at 18 seconds in the first clip - 0.4mm end-mill in brass. Never ceases to amaze how resilient these little cutters can be..! Everything cut dry, just a bit of air.
    In that middle clip you can see that the cog plaque has a more pronounced meniscus effect - you're seeing it before the final clear coat of resin which I added to the process. It flattens out the effect, but will serve to protect the plaque and add to its longevity - the resin's pretty tough stuff. These are being installed as paving slab way-markers in North Manchester - it'll be interesting to see how they get on being walked on all day.
    Wal.
  4. The Following User Says Thank You to Wal For This Useful Post:
  1. Larger Open CNC Design
    Last Post: 17-07-2017, 04:51 PM
  2. larger stepper motor needed
    By terry1956 in forum General Electronics
    Last Post: 29-05-2017, 05:35 PM
  3. Replies: 3
    Last Post: 10-03-2016, 09:25 AM
  4. Replies: 11
    Last Post: 01-06-2014, 04:40 PM
  5. Truss Structures - in larger gantry router design
    By CharlesJenkinson in forum Gantry/Router Machines & Building
    Last Post: 10-02-2014, 09:56 PM
