    Just found out about this German company who design in Germany and build in Asia called Optimum Machines.
    http://www.optimum-machines.com
    I have seen that their little desktop mills get converted a lot but they are releasing some VMCs over the past couple years that are quite small.
    Found them through a video, https://www.youtube.com/watch?v=-K4B0_I9oJA
    Looks like the UK seller is http://www.excelmachinetools.co.uk/
    Anyone heard of them, know much about their machines, thoughts?
    Obviously not in a position to buy but interested in finding out more info.
    Chaz's Avatar
    It be curious about pricing. Standard looking machines. The smaller ones have spindles that are very underpowered.
    The larger one runs on 3 phase which is a problem for most of us. 8000 rpm is OK for most stuff, BT30 is nice. Id estimate this machine to cost somewhere between £10 - 15K, if not a bit more.
    I know that the F80 is £30-35k.
    The F2 looks a tad too small to me. F3 would be alright.
    And yea three phase but should be able to use single to three phase converter as it won't be that much HP?
    Chaz's Avatar
    Quote Originally Posted by JOGARA View Post
    £30K, ouch. This is why I built my own machine.
    There are ways to sort out 3 phase requirements, often its just the spindle motor and/or a coolant pump that needs 3 phase. Most of which can easily be changed.
    Id rather look at a smaller Haas mill for £30K or have something built.
    Price from http://www.excelmachinetools.co.uk/
    F2 Mini Vertical CNC Mill £ 14,450.00
    F3 Mini Vertical CNC Mill £ 17,995.00
    Plus VAT and Postage
    Pretty sure this is base price, ATC and extras on top...
    Chaz's Avatar
    The Y Axis movement on the F2 / F3 machines is very restrictive too.
    These machines are not too bad though.
    I think the castings are all done by Syil. (Was talking to Aaron Powter about this earlier this morning)
    For a little less money, you can get the Syil S7 or X7 Combo nowdays, delivered and inclusive of VAT. (Just quoted for one with a Siemens 808D/Advance)
    <---- scratch that, I saw the price of the Haas, not the ones by Jogara
    There is also the option of the Skyfire if you are happy to wait.
    https://emvioeng.com
    Quote Originally Posted by komatias View Post
    I have been looking at Skyfire a lot recently (again not in a position to buy a VMC or a little VMC).
    They look okay but they are flaky on support as there is language barrier and there are a few quirks with their machines that the SF community have and are working on fixing.
    Syil S7 looks to be around £23,000 with enclosure, 8080D, ATC (16 of course) before import and shipping? Only looked on their own website, not a dealer.
    Apart from the top couple of models the Opti models look like CNC'd small vertical milling machines, on a stand, in a box and lacking a proper VMC Chassis.
    If you're looking at a non-tool changer model why not convert a manual mill and build your own stand and box, sliding doors aren't that expensive to build ;-)
    I think I would want ATC if I get to that stage xD
  1. Optimum air pressure for the laser air assist?
    By Want2build1 in forum Laser Machines & Building
    Last Post: 13-05-2014, 09:50 AM
  2. Optimum voltage for M60STH88-3008DF steppers and 752 drivers?
    By Mad Professor in forum Stepper & Servo Motors
    Last Post: 26-08-2012, 09:38 PM
  3. CONVERSION: Optimum BF20L Conversion
    By Rikk in forum Conversion Build Logs
    Last Post: 17-07-2011, 06:00 PM
  4. optimum diameter???
    By m.marino in forum Lead Screws, Nuts & Supports
    Last Post: 02-04-2010, 12:44 AM
