    Chaz's Avatar
    The Y Axis movement on the F2 / F3 machines is very restrictive too.
    These machines are not too bad though.
    I think the castings are all done by Syil. (Was talking to Aaron Powter about this earlier this morning)
    For a little less money, you can get the Syil S7 or X7 Combo nowdays, delivered and inclusive of VAT. (Just quoted for one with a Siemens 808D/Advance)
    <---- scratch that, I saw the price of the Haas, not the ones by Jogara
    There is also the option of the Skyfire if you are happy to wait.
    https://emvioeng.com
    Quote Originally Posted by komatias View Post
    I have been looking at Skyfire a lot recently (again not in a position to buy a VMC or a little VMC).
    They look okay but they are flaky on support as there is language barrier and there are a few quirks with their machines that the SF community have and are working on fixing.
    Syil S7 looks to be around £23,000 with enclosure, 8080D, ATC (16 of course) before import and shipping? Only looked on their own website, not a dealer.
    Apart from the top couple of models the Opti models look like CNC'd small vertical milling machines, on a stand, in a box and lacking a proper VMC Chassis.
    If you're looking at a non-tool changer model why not convert a manual mill and build your own stand and box, sliding doors aren't that expensive to build ;-)
    I think I would want ATC if I get to that stage xD
    The F3 is not ATC
    The F3 is not ATC
    Thought it might not.
    Pretty much only looking at the F80 now as well because of the work envelope.
    £30-35k is super expensive. Haas vmc's start at £20k and XYZ machinetools do good mills less that £35k and they are all BT40 spindles so more rigid
  1. Optimum air pressure for the laser air assist?
    By Want2build1 in forum Laser Machines & Building
    Last Post: 13-05-2014, 09:50 AM
  2. Optimum voltage for M60STH88-3008DF steppers and 752 drivers?
    By Mad Professor in forum Stepper & Servo Motors
    Last Post: 26-08-2012, 09:38 PM
  3. CONVERSION: Optimum BF20L Conversion
    By Rikk in forum Conversion Build Logs
    Last Post: 17-07-2011, 06:00 PM
  4. optimum diameter???
    By m.marino in forum Lead Screws, Nuts & Supports
    Last Post: 02-04-2010, 12:44 AM
