    I thought the UC400 needed a power source as its got the + - connectors?
    Quote Originally Posted by Palletlad View Post
    Yes, it does. Any voltage, from 12V through 24V DC, according to the manual, and with a current rating between 500mA and 250mA (Multiply the voltage and the current to get the power requirement, e.g. 12 x 0.500 = 6Watts, or 24 x 0.250 = 6Watts : basically it needs 6 Watts of power).
  3. The Following User Says Thank You to Doddy For This Useful Post:
    So am I right in thinking the VFD is safe to have wired up to the 48v 5amp 220 PSU Doddy with your explanation?
  5. #4
    The D100S1R5B VFD does not need any power supply, it is plugged into the wall socket and is a power supply to the spindle. The the motion electronics (driver, motion controller and such) plus the stepper needs DC power supplies. I don't know where you would connect the 48V to the VFD.
  6. #5
    Sorry I got confused as the original setup they have daisy chained the VFD and PSU to the same wires so for a novice like me it looked like the power went through the psu first then the vfd.
  7. #6
    What do you mean by daisy chained? The VFD and the PSU must be connected in parallel on the mains side.
  8. #7
    The term "daisy chain" can be applied to parallel-connected devices.
  9. #8
    Erm.!! . . . Are you sure what your calling VFD is actually a VFD.?
    To be honest from the looks of the questions your asking it's clear your level of electrical knowledge is very low so maybe you should back off a little and maybe seek help from someone who has more knowledge. Because when comes to PSU and VFD's your dealing with mains voltage which WILL KILL YOU without asking if you know what your doing.!
    I'm strongly advising you to ask your self if your capable. I'd also strongly suggest you don't turn anything on untill your 100% sure know it's correct or get it checked by someone who does.
    We can help you but only to a point and if you don't understand the basics then it's very easy to blow expensive things up or god forbid much worse.!!
  10. #9
    Thank you for the concern I don't deny I know nothing in regards to electrics, I have now sat down and had a lengthly chat with a trained technician (took your advice) and went through a lot of questions about wiring and power usage whilst going through the wiring with a dvm.
    My "daisy chain" term I used was actually a "series" connection.
    And I was shown that the vfd is connected to the live and neutral connectors on the psu so was getting a DC from the mains and not through the psu.
    What I will do is draw up a diagram of my wiring and get it double checked.
  11. #10
    PalletLad: one of us is confusing the other: the VFD takes a mains supply.
    You can wire the same mains feed to both the VFD and to the PSU but the PSU does not provide an electrical supply to the VFD
  1. Power supply help
    By Davo242 in forum General Electronics
    Last Post: 07-01-2016, 01:00 AM
  2. Power supply
    By racerbear02 in forum Laser Machines & Building
    Last Post: 13-09-2015, 09:27 AM
  3. FOR SALE: power supply
    Last Post: 14-09-2014, 03:19 PM
  4. Replies: 0
  5. FOR SALE: 50V 20A Power supply
    Last Post: 30-05-2011, 11:01 PM
