Thread: Mach3 Help required
11-04-2018 #5
That doesn't quite make sense Gerry! The inputs are connected to the computer and require 5v/gnd to drive the buffer circuit. If the optocouplers have no buffering then the 5v is unnecessary as the LED in the opto is driven directly from the signals and ground connections in the D25 cable. You will then need 5v to bias the photo transistor in the output stage, which should be derived from a power source other than the computer 5v in order to give the galvanic separation.
The USB socket on this board connects through to two terminals labelled PC 5v and PC GND and these I just connect to the power supply 5v/GND - it works.
I probably have a spare one of these boards and if I find it I will have a poke round it with a meter.
I may not be 100% correct, but it ain't worth a dick slapping contest.
new software license required, mach3 or mach4?
By Noplace in forum Artsoft Mach (3 & 4)Replies: 8Last Post: 04-04-2016, 12:00 AM -
What machine is required please
By Arzo10 in forum Machine DiscussionReplies: 19Last Post: 06-03-2016, 12:01 AM -
WANTED: Off-cut required.
By Wal in forum Items WantedReplies: 8Last Post: 14-12-2015, 11:09 PM -
Help required with desktop cnc build - cutting out the required plates
By alanb in forum OpenBuilds OX CNC MachineReplies: 0Last Post: 08-07-2014, 03:11 PM -
NEW MEMBER: Help required
By Vespa Mad in forum New Member IntroductionsReplies: 1Last Post: 24-06-2009, 02:06 PM
