02-02-2019 #1home your machine then zero the X then in the MDI put g0x100 f500 and check if the machine moves 100mmEverything is setup to mm.
02-02-2019 #2
02-02-2019 #3If I put g0x100 f500, my machine will run out of its limits. But if I put g0x10 f500 it will move 100mm (10cm) perfectly.
Well then I think that the steps per are wrong on the drives..Clive
02-02-2019 #4
02-02-2019 #5
The co-ord stuff and scaling is sometimes iffy.
Mostly, it is not wrong, necessarily.
If the machine was set up with a certain abs. position, homed, then you use a different offset g54xx, it is unclear which units should be used.
Since the work co-ords are not tied to a scalar, how is the sw to know what is/was the correct offset base in global terms.
If a work co-ord is offset say 10,0 mm, and I switch to imperial, should the offset base adjust by /25.4. Why ?
Likewise, should the machine global values adjust, or not ?
Why ?
If the home switch in z is offset 10.000- mm in z, metric, and I switch to imperial, should the home-pos value adjust ?
If I read in the value into a parameter say #3000, should that number adjust ?
Why ?
I am NOT saying it is right, logical, correct.
What I am pointing out is that it is very complex with no clear right answers, mostly.
The UCxxx, and the chinese offline controllers, are mostly much less complex and donīt support a lot of the features in gcode.
02-02-2019 #6
Good call Clive!
I rarely think of the basic machine set up being at fault! :DYou think that's too expensive? You're not a Model Engineer are you? :D
The Following User Says Thank You to magicniner For This Useful Post:
02-02-2019 #7
I got it figured out! It was an extra decimal point. i.e step per was set 2000.xxx instead of 200.xxx
I guess, I assumed the step per start at 1600 and goes up.
Appreciate your help, everyone!
Now the step per is resolved, I need help to figure out why everything except square, rectangle, and straight lines come up deformed.
The shapes below were supposed to be 20mm circle, and 20x20x20mm triangle.
02-02-2019 #8Could be missing steps ie. acceleration too high or voltage to the steppers too low. Or even excessive backlash. Or couplings loose on the motors.Now the step per is resolved, I need help to figure out why everything except square, rectangle, and straight lines come up deformed.
Glad you got the steps per right now.Last edited by Clive S; 02-02-2019 at 11:05 PM.
02-02-2019 #9
Weird Mach3 + CSMIO/IP-M Probe Problem
By matt-b2 in forum General DiscussionReplies: 24Last Post: 11-07-2019, 01:05 PM -
The best CAD/CAM suggestion, Gcode and Mach3
By petes in forum CAD & CAM SoftwareReplies: 1Last Post: 29-01-2015, 11:06 AM -
Help needed for a 3d part gcode for mach3
By Rebekah_harper in forum Computer SoftwareReplies: 33Last Post: 04-11-2013, 01:55 AM -
Mach3 Using a physical button to repeat current gcode
By RLKS Rob in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 12-08-2012, 01:30 PM -
Day shift Manual Miller/Night Shift Turner and Grinder Required - Berkshire
By J Maynard in forum Opportunities Available & SoughtReplies: 0Last Post: 06-01-2012, 11:46 AM
