11-04-2018 #2
Well, I've probably found the answer myself. It was only while starting to write this post that I actually understood what was happening - at first, I didn't even realise that it was due to an in/mm issue - and as a result googling around for answers wasn't very useful. You do need to know the right question before you can get the right answer...
Looks like Mach3 doesn't really handle in/mm G20/21 commands the way I would expect. However, it should work OK (according to what I have read) if you load the gcode, and then set the work coordinate zero. I was setting the work coords and then loading gcode. It still doesn't make much sense to me, but at least it looks like a way to handle gcode created using the "other" set of units.
Weird Mach3 + CSMIO/IP-M Probe Problem
By matt-b2 in forum General DiscussionReplies: 24Last Post: 11-07-2019, 01:05 PM -
The best CAD/CAM suggestion, Gcode and Mach3
By petes in forum CAD & CAM SoftwareReplies: 1Last Post: 29-01-2015, 11:06 AM -
Help needed for a 3d part gcode for mach3
By Rebekah_harper in forum Computer SoftwareReplies: 33Last Post: 04-11-2013, 01:55 AM -
Mach3 Using a physical button to repeat current gcode
By RLKS Rob in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 12-08-2012, 01:30 PM -
Day shift Manual Miller/Night Shift Turner and Grinder Required - Berkshire
By J Maynard in forum Opportunities Available & SoughtReplies: 0Last Post: 06-01-2012, 11:46 AM
