16-02-2019 #12
Sorry for the late response. But I got it figured out, well, at least the mechanical part.
For some reason the mach3 won't take any backlash compensation values.
I tested the backlash using a dial indicator gauge, I'm getting readings of 0.03-0.06mm distributed between all these axes. However, when I enter the values in the mach3 backlash settings nothing happens.
I have tried it using the default 20% all the way to 100% without any changes within the dial gauge reading.
Is any of you guys is using the backlash compensation?
I am using pokeys57cnc as a motion controller.
As always, thanks in advance!
Weird Mach3 + CSMIO/IP-M Probe Problem
By matt-b2 in forum General DiscussionReplies: 24Last Post: 11-07-2019, 01:05 PM -
The best CAD/CAM suggestion, Gcode and Mach3
By petes in forum CAD & CAM SoftwareReplies: 1Last Post: 29-01-2015, 11:06 AM -
Help needed for a 3d part gcode for mach3
By Rebekah_harper in forum Computer SoftwareReplies: 33Last Post: 04-11-2013, 01:55 AM -
Mach3 Using a physical button to repeat current gcode
By RLKS Rob in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 12-08-2012, 01:30 PM -
Day shift Manual Miller/Night Shift Turner and Grinder Required - Berkshire
By J Maynard in forum Opportunities Available & SoughtReplies: 0Last Post: 06-01-2012, 11:46 AM
