    That code works just fine on my install of Mach3.
    Where did you buy your Mach3 License, is it in your name?
    Are the "units per" settings in the Mach3 config correct, or did someone use cm instead of mm there?
    The mach3 units per are config to mm.
    When I go under the config > select native units > there're 2 options only, inches and mm. and mine is set to mm.
    Can you set it to use a cm instead of mm? If so, how to change it back to mm?
    Thanks!
  5. #4
    Yes, the license is mine. I purchased it from a local woodworking shop.
  1. Weird Mach3 + CSMIO/IP-M Probe Problem
    By matt-b2 in forum General Discussion
    Last Post: 11-07-2019, 01:05 PM
  2. The best CAD/CAM suggestion, Gcode and Mach3
    By petes in forum CAD & CAM Software
    Last Post: 29-01-2015, 11:06 AM
  3. Help needed for a 3d part gcode for mach3
    By Rebekah_harper in forum Computer Software
    Last Post: 04-11-2013, 01:55 AM
  4. Mach3 Using a physical button to repeat current gcode
    By RLKS Rob in forum Artsoft Mach (3 & 4)
    Last Post: 12-08-2012, 01:30 PM
  5. Day shift Manual Miller/Night Shift Turner and Grinder Required - Berkshire
    By J Maynard in forum Opportunities Available & Sought
    Last Post: 06-01-2012, 11:46 AM
