16-02-2019 #31
Sorry for the late response. But I got it figured out, well, at least the mechanical part.
For some reason the mach3 won't take any backlash compensation values.
I tested the backlash using a dial indicator gauge, I'm getting readings of 0.03-0.06mm distributed between all these axes. However, when I enter the values in the mach3 backlash settings nothing happens.
I have tried it using the default 20% all the way to 100% without any changes within the dial gauge reading.
Is any of you guys is using the backlash compensation?
I am using pokeys57cnc as a motion controller.
As always, thanks in advance!
16-02-2019 #32
I use Backlash Compensation in Mach3 and it works perfectly.
You're not just using the latest version thinking that will be best are you?
It isn't, the versions after the company changed hands are variations that range from Inexperienced Mash Up through to Truly Not Worth Using.
Just so you know ;-)You think that's too expensive? You're not a Model Engineer are you? :D
17-02-2019 #33
Weird Mach3 + CSMIO/IP-M Probe Problem
By matt-b2 in forum General DiscussionReplies: 24Last Post: 11-07-2019, 01:05 PM -
The best CAD/CAM suggestion, Gcode and Mach3
By petes in forum CAD & CAM SoftwareReplies: 1Last Post: 29-01-2015, 11:06 AM -
Help needed for a 3d part gcode for mach3
By Rebekah_harper in forum Computer SoftwareReplies: 33Last Post: 04-11-2013, 01:55 AM -
Mach3 Using a physical button to repeat current gcode
By RLKS Rob in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 12-08-2012, 01:30 PM -
Day shift Manual Miller/Night Shift Turner and Grinder Required - Berkshire
By J Maynard in forum Opportunities Available & SoughtReplies: 0Last Post: 06-01-2012, 11:46 AM
