No, nothing at all. Mach4 uses Lua.
Mach4 is far more complex than Mach3, and programming in Lua will require a much better understanding of how Mach4 works than the simple VB scripts in Mach3 do.
Also remember the reason you have problems in the first place. Artsoft writes the software, and third parties develop hardware and write plugins to interface their hardware. For this reason, you'll find that Mach3 functions can and do work very differently, depending on how the plugin for the hardware is written.
Artsoft thought this method worked so well, they'd stick with it for Mach4.
It was CS Labs decision to write their Mach3 plugin the way they did. So your Mach4 experience will be heavily reliant on CS Labs, as is your Mach3 experience.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
16-04-2018 #2
Thanks Gerry, makes sense.
I think the best solution would be CSLABS own software but i'm going to have to let that mature a bit i think, its still in beta and is very restricted at present.
22-04-2018 #3
Hi, you could have a look at Tormach Pathpilot and there is info on you tube. http://pathpilot-on-nontormach.wikia.com/wiki/Main_Page. They were Mach people until recently. The benefit of this route appears to be the DIY following and a company in the US who want it to work.
I am looking (still!) at doing a conversion and i think moving away from computers is the best route and it appears that single box controllers are the way to go and how much you spend will depend on the value you put on reliability and back up.
22-04-2018 #4
I have managed to fix the issue now.! :)
For some odd reason, trying to run probing routines with a CSLABS controller from within a Mach3 wizard is NOT a good idea at all.
In the end i created my own custom screen set for Mach3 and it all works perfectly now, no instability and very good results.
A painful lesson but worth it in the end :)
Lathe ATC Options?
By Ross77 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 35Last Post: 28-08-2020, 12:13 AM -
6 wire motor options
By Ross77 in forum Motor Drivers & ControllersReplies: 8Last Post: 27-03-2017, 10:04 AM -
PC Upgrade Options?
By Chaz in forum General DiscussionReplies: 11Last Post: 31-08-2016, 04:53 PM -
ATC Options?
By Davek0974 in forum Gantry/Router Machines & BuildingReplies: 25Last Post: 14-05-2016, 08:25 AM -
options for 3020 router spindle?
By arborealad in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 19-11-2012, 10:13 PM
