Page 2 of 2 FirstFirst 12
    I have a spare one Chaz if it works ok we can sort something out.
    We use them at wok and they are built very well.
    Andy
  2. The Following User Says Thank You to audioandy For This Useful Post:
  3. #12
  4. #13
    Lives in East Lothian, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Does this need a 'receiving part' or anything that it can pick up in the slot?
    You need something that goes through the slot. It doesn't have to be anything fancy, I just used a bit bent bar suitably mounted on the cross slide -
  5. we use these on our machines and linear stages we build.
    https://www.zappautomation.co.uk/bes...on-sensor.html
    The repeatable accuracy is 1% of the distance of the metallic material used to sense.
    other things also need to be taken into account as well to see the accuracy though.
    Also very low profile, but not the cheapest.
  6. #15
    Chaz, I have made something based on the "touch plate" concept used for mill Z homing.
    (I hope that works!)
    Repeatability seems to be better than 10 microns, and in conjunction with my tool setter on my first trial of homing/applying set tool offset/turning I achieved indicated microm accuracy on diameter. This cost nothing to make, it's essentially a bit of PCB laminated on to 6mm of tufnol superglued to the apron front. Obviously there are issues of wear and tarnishing so I intend to upgrade it with one where the contact surface is beryllium copper.
  7. #16
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 1 Week Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    Quote Originally Posted by JohnHaine View Post
    Thanks, I had though of similar - this is the way that we deal with milling offsets, so no reason why it wont work on a Lathe. Ill try the switch from audioandy (Thank you) first and go from there.
    Thanks for the other suggestion Gary.
  8. #17
    Hi Chaz
    Switch posted today first class so should be with you tomorrow.
    Regards
    Andy
  9. #18
    Chaz's Avatar
    Quote Originally Posted by audioandy View Post
    Hi Chaz
    Regards
    Andy
    Thanks, appreciated.
    I retested my cheap proximity switch with a 'semi decent' analog DTI and it was surprisingly accurate. My el cheapo electronic DTI seems not to be repeatable. Go figure ...
    I also managed to get my spindle speed / encoder setup to work and tweaked my steps for X and Z, explains why I was getting inaccurate cuts, not out my much, but it was out.
    Ill still try the mechanical switch - just need to figure how to mount it with my setup.
  10. #19
    Chaz's Avatar
    Hi Chaz
    Regards
    Andy
    Received, with thanks.
  11. The Following User Says Thank You to Chaz For This Useful Post:
  12. #20
  1. Homing with proximity sensors
    By routerdriver in forum General Electronics
    Last Post: 19-12-2017, 06:32 PM
  2. Problem with homing
    By Andyman in forum Gantry/Router Machines & Building
    Last Post: 22-03-2016, 07:56 PM
  3. homing problems in mach3
    By johngoodrich in forum Artsoft Mach (3 & 4)
    Last Post: 17-09-2011, 08:28 PM
  4. Homing Switches
    By m_c in forum General Electronics
    Last Post: 04-11-2010, 11:21 PM
  5. Limits or homing switchs???
    By Ross77 in forum Computer Software
    Last Post: 28-03-2010, 03:17 AM
