Thread: High Precision Homing Switch
15-04-2018 #2
I used an opto slot sensor on my old lathe, and there was never any measurable variation. I used RS part number 480-5231 however I see that part has now been discontinued. The only problem was I had to make sure a bit swarf hadn't landed in the slot prior to homing, as I never bothered enclosing it.
The new lathe uses proximity combined with servo index homing.
You could combine a proximity or microswitch with a slot sensor on the stepper, provided you can add a suitable slot to the stepper/ballscrew, to essentially give you a poor mans index homing.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following User Says Thank You to m_c For This Useful Post:
15-04-2018 #3
Chaz
I have a Balluff mechanical switch which are very good, I don't mind sending it over for you to try.
Just pm me your address if you want to try it. I will post a link to the switch if I can find it on the RS site.
Regards
Andy
15-04-2018 #4
15-04-2018 #5
I have a spare one Chaz if it works ok we can sort something out.
We use them at wok and they are built very well.
Andy
The Following User Says Thank You to audioandy For This Useful Post:
15-04-2018 #6
Here is a link to the pdf Chaz
http://www.balluff-ua.com/pdf/mechan..._single_EN.pdf
15-04-2018 #7
Thanks, something like this - https://uk.rs-online.com/web/p/photo...nsors/1254515/ ?
15-04-2018 #8
15-04-2018 #9
16-04-2018 #10
we use these on our machines and linear stages we build.
https://www.zappautomation.co.uk/bes...on-sensor.html
The repeatable accuracy is 1% of the distance of the metallic material used to sense.
other things also need to be taken into account as well to see the accuracy though.
Also very low profile, but not the cheapest.Last edited by Gary; 16-04-2018 at 07:38 AM.
Visit Us: www.automationshop.co.uk
Homing with proximity sensors
By routerdriver in forum General ElectronicsReplies: 4Last Post: 19-12-2017, 06:32 PM -
Problem with homing
By Andyman in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 22-03-2016, 07:56 PM -
homing problems in mach3
By johngoodrich in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 17-09-2011, 08:28 PM -
Homing Switches
By m_c in forum General ElectronicsReplies: 3Last Post: 04-11-2010, 11:21 PM -
Limits or homing switchs???
By Ross77 in forum Computer SoftwareReplies: 11Last Post: 28-03-2010, 03:17 AM
