    Also the spindle bearing is 20 odd years old, mine went and i had to change it.
    Bearings don't last forever
    Lives in East Lothian, United Kingdom. Last Activity: 3 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    My mod was quite a bit of work. I think the lathe work alone took about 3-4 hours, as it was a big lump of bar to hollow out.
    Now I've had time, this post gives the process of renewing the bearings - http://www.mycncuk.com/threads/10344...8817#post88817
    And the spindle motor mods start a bit further down that page - http://www.mycncuk.com/threads/10344...9732#post89732
    Thanks to everyone who has replied, it really is very much appreciated.
    Chaz-Tightening the two bolts holding the motor has eliminated nearly all the noise for now. However the top bearing support is still getting hot. Thanks very much for your rapid response and friendly advice.
    MC- Thanks I will take a look at those links you have posted and hopefully get some ideas about a long term solution to mounting the motor.
    Andy- I looked at an old post of yours on the Denford Forum and hoped that you might have some good advice. Did you replace your bearings like for like or did you upgrade when you made the swap?
    Thanks again guys
    Wow MC that is outstanding work on that Mod! Really inspiring stuff.
    Quote Originally Posted by Lieutenant Swarf View Post
    I was lucky in that I had time to design a suitable mod, and didn't have to rush and make do with whatever I could my hands on.
    If you want the fusion 360 files or any drawings, let me know and I can email them across. To design it I had to create a model of the head casting, so I could see what would/wouldn't fit.
  6. The Following User Says Thank You to m_c For This Useful Post:
  7. #6
    That would be fantastic. Thank you very much. I will PM you my email address.
  8. #7
    Where in the UK are you?
  1. Yet another Denford triac at fault!
    By jamesgates1000 in forum Denford Mills
    Last Post: 23-02-2018, 04:43 PM
  2. Denford Triac Spindle control / ATC
    By RocketBoy in forum Denford Mills
    Last Post: 24-01-2018, 12:35 PM
  3. 3kw Chinese Spindle - ER20 denford triac question
    By andy_con in forum Denford Mills
    Last Post: 03-11-2015, 10:14 PM
  4. Dell monitor making a funny noise !
    By Lee Roberts in forum Monitors
    Last Post: 13-09-2013, 12:11 PM
  5. Denford Triac Spindle Fault
    By Sam_Smith in forum Denford Mills
    Last Post: 04-05-2011, 11:07 PM
